What color is it??? Nitrate check.
Not expired, and it wasn't brownish?? We'll see what the next check brings us a couple of months.
How did you test? I normally just clip the strip on the end of a long hemostat and dunk in the degas bottle. As long as you do this when the coolant is in the proper test temp range around 75F this is good. The degas bottle has circulation and is not an overflow container that the test instructions warn about.
I've seen that more orange-mud color before and it did seem to relate to old test strips. Strips are cheap though, so you can certainly do a second test to see if it's the same.
No, you can do the test from any point in the system that has constant circulation, and the degas bottle has constant circulation. You are not supposed to test from a location that doesn't have circulation such as an overflow / recovery tank. The degas bottle is not an overflow / recovery tank.
montana_highboy
15
07-25-2009 11:01 PM
