Water pumps 1950 truck - Ford Truck Enthusiasts Forums
Old 06-14-2013, 12:39 PM
1950F2 1950F2 is offline
1950F2 is starting off with a positive reputation.
I purchased 2 rebuild kits for my 239 engine.(wide pulley)5/8" Found out that I have one pump with the larger dia. shaft and the other is smaller than in the kit.
Does any one have a "core " that I can buy to rebuild??
Need drivers side. I guess I need the pump style that does not have the lube
hole in it.
Help Installing Wooden Bed - 1950 F1 nigeljoiner 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 09-10-2014 07:18 PM
1950 overflow tank install 1950F2 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 04-04-2014 05:40 PM
1950 f1 steering box upgrade 1950 boy 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 05-22-2009 10:15 AM
Is this the right engine? TRUCKDOG 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 10-30-2005 02:42 AM
carb rebuld kit for f-3 with flathead v8 granitehauler Flathead V8 & Flathead 6 8 01-07-2003 10:34 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
