2007 Navigator L Sound Problems - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-14-2013, 09:11 AM
jimb726 jimb726 is offline
jimb726 is starting off with a positive reputation.
I have a new to me Lincoln Navigator L. In a nutshell the soundsystem sounds terrible. Very little bass, hollow sounding. If I were a betting man I would say that an amplifier isnt working or is failing. I had it into a delaer and they claimed it was fine but I have been in other Navigators that sound worlds better than this, even my F350 sounds much better. Any suggestions on what I can check to see what the problem might be?
Thanks in Advance
Old 06-14-2013, 11:03 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Do all the speakers sound bad? Put the sound field to ALL SPEAKERS and then move the balance and fade to each speaker. Do they sound similar? Is the sub working? How does the AUX INPUT sound VS. CD?
Old 06-14-2013, 12:07 PM
Quote:
They all sound tinny, the sub works, but doesnt sound powered, all speakers sound the same. It does sound better when I use the rear seat entertainment but, for example, in order to hear a movie, i need to have the volume well over 1/2 way. Its a wierd thing but I know its not right, but I dont know why its not right.
Old 06-14-2013, 02:12 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
The navigator had a different system (THX certified if I am not mistaken) than the Expedition. However my 13 KR with the bass set on 0 still thumps pretty good. I would take it in and see what the dealer says, I've never been in a navigator that sounded tinny granted I've only been in two or 3 so it's hard to tell for sure.
Old 06-14-2013, 02:18 PM
Quote:
I did take it in and they said it was fine. Of course they werent able to verify the drivers window that wouldnt go down, or the rear quarter window that wouldnt open, unfortunately for me, my extended warranty expired before I could get it to another dealer so now I am stuck self-diagnosing.
Old 06-14-2013, 09:06 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
What stereo is in it ? Navigation or just CD ?
Seeing as you bought it used, are you 100% sure it has the correct radio in it ? ( The way it came from the factory)
Navigators used a seperate DSP amp/module between the radio and the speakers. The unit is mounted in the dash around where the console and dash meet.
Try unplugging the amp on the top of the sub and see if it changes anything. ( should be able to just pull the 3rd row cup holder on drivers side and reach in to disconnect it )
Have you tried doing the speaker walk around test ?
Matt
Old 06-14-2013, 09:23 PM
Matt
It's the nav radio, definitely correct and original to the vehicle. I have the original window sticker. It was actually replaced under warranty (the radio) due to inoperative nav. I've heard of the walk around test, not sure how to do it?
Thanks,
Jim
Old 06-15-2013, 04:50 PM
RI-Matt's Avatar
Jim for the speaker walk around test try this.
1.Turn the audio unit on.(FM/AM)
2.Press and hold preset buttons 3 and 6 for 3 seconds. The speaker walk-around test will begin.
Also, there is a chance that when they replaced the radio under warranty that it wasn't programmed correctly.
Have you checked the fuses for the THX amp? I think they are #38 and #40.
Matt
Old 06-15-2013, 10:22 PM
Matt
Ok, first I really appreciate the help. It seems that the walk around test worked, all the speakers that were supposed to make sound did. I did find and check each fuse, they are both good, the weird thing is, when I pulled each fuse there was no change in sound quality. Shouldn't pulling the fuses cause the sound to change?
Old 06-15-2013, 10:51 PM
Quote:
If those were the fuses for the radio yes, I believe it should have caused the AMP to drop out, I'm not sure if you unplugged the AMP why sound would still be coming out. On any system I've ever had / installed a dead amp equals no beats. I would double check your wiring diagram to make sure the fuses you pulled were in fact for the amp powering the speakers.
Old 06-16-2013, 06:56 AM
RI-Matt's Avatar
Jim,
Can you go back and do the speaker walk around test again but this time press the "End Test" button. This will bring up another screen labeled "Bezel Diagnostics".
Press the "Configuration Status". Write down all the info listed ( ie. AM Test Station, THX DSP........) make sure to scroll down as there are about 4 pages of info.
Then press "Return" which will bring you back to that first screen.
Now press "System Info", again write down what it says ( ie. Nav Radio Part Number......)
Matt
Old 06-17-2013, 07:57 AM
Jim,
Matt
As Requested
Radio Configuration Status:
AM Test Station 1170
THX DSP Not Available
FES Available
RSEM Not Available
SDARS Available
Phone Module Not Available
Clock Display Off
Convertible Not Enabled
Center Amp Enable Not Enabled
Stereo II Input Enabled
Surround 5.1 Not Enabled
External Amp Not Enabled
Subwoofer Not Enabled
HEV Disabled
CID Disabled
SWC POD Type 5 Position
Brand Lincoln
SWC 2 POD Type 5 Position
Run/ACC H/W
Illumination MS-CAN
Vehicle Speed MS-CAN
Reverse Park Aid Not Used
SWC H/W
Delay Accessory MS-CAN
FES Multi-channel Enabled
SWC 2 H/W
Language English
Reverse Gear N/W
Display Units English
Voice Recognition Enabled
Limited FES Disabled
Back Illum. Color White
System Information:
Nav Radio Part Number 7L7T-18K931-EB
Audio/System Software Version 3-9-21-2006
Nav. Soft Version 3.040000
FES Software Product ID 8-0-0-7-2
SDARS Software Product ID 30-0-0-7-3
PSC Software Product ID - - - -
DSP Software Product ID 0-80-20-7-2
Hopefully this makes sense, lol. Again, thank you for your help.
Jim
Old 06-17-2013, 08:35 AM
RI-Matt's Avatar
Jim
Unfortunately that's kind of what I expected. It looks like the unit was not properly programmed for your vehicle because I believe the THX DSP is supposed to be enabled as well as the subwoofer. What you need to do is have the dealer check another navigator in the same way to see if those functions are Enabled on a similar model. You said the radio was replaced under warranty, was that while you owned it or the previous owner?
Matt
Old 06-17-2013, 09:55 AM
Jim
Matt
I had the same question in my mind as soon as I started typing these for you. We bought the Navigator in February and it came with the balance of the Certified Pre Owned vehicle warranty. We had an issue where the nav unit kept freezing up and we had some other issues so we took it in to get everything replaced all at once, including the navigation unit. The dealer is a real jerk and my CPO has since expired so I am dreading calling them to get this straightened out. This isnt something that can be enabled outside the dealership is it?
Jim
Old 06-17-2013, 06:23 PM
RI-Matt's Avatar
Might try these guys, I think they do reprogramming.
United Radio - Automotive Electronics - Quality Electronics Service Since 1923
Also, you might want to check and make sure the DSP/Amp is still in the vehicle and not removed by previous owner.
If you send me a PM with your email I can send you the pdf on how to remove it.
Matt
Mustang sound brentkhack 1997-2006 Expedition & Navigator 1 08-07-2014 11:24 AM
Magnaflow Cat Back Exhaust 68bluebeast 1997-2006 Expedition & Navigator 4 01-21-2014 09:23 PM
2010 Navigation in 2008 Navigator JLun21 Mid-West Region 0 07-23-2012 04:36 PM
Lincoln Navigator and Navigator L fuel mileage and offroad ability? kip42 2007 - 2014 Expedition & Navigator 4 01-13-2011 02:46 PM
Navigation System dlafleur 1997-2006 Expedition & Navigator 8 11-29-2004 01:51 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
