2007 Navigator L Sound Problems
Might try these guys, I think they do reprogramming.
United Radio - Automotive Electronics - Quality Electronics Service Since 1923
Also, you might want to check and make sure the DSP/Amp is still in the vehicle and not removed by previous owner.
If you send me a PM with your email I can send you the pdf on how to remove it.
Matt
Matt
Jim
No I dont believe it is. I think it has to be done through a computer software program.
Matt
Well if anyone cares I think I have it coming to a resolution. After fighting with the service advisor for the last 6 weeks, I finally got to the Service Manager, long story short, they were able to identify, as Matt speculated, that the radio was never programmed correctly by the original technician. Shocker. I am set to drop off the car Monday for hopefully the last time.
Hi n
What stereo is in it ? Navigation or just CD ?
Seeing as you bought it used, are you 100% sure it has the correct radio in it ? ( The way it came from the factory)
Navigators used a seperate DSP amp/module between the radio and the speakers. The unit is mounted in the dash around where the console and dash meet.
Try unplugging the amp on the top of the sub and see if it changes anything. ( should be able to just pull the 3rd row cup holder on drivers side and reach in to disconnect it )
Have you tried doing the speaker walk around test ?
Matt
Matt
'78 Custom
05-18-2006 01:57 PM
Ksauers
02-10-2006 05:38 PM
ftrain
07-20-2002 10:18 PM
