fuse blows when key on
06-14-2013, 12:17 AM
97 F150 4.2 auto with Simple trans pan gasket change because it was leaking and now the ign fuse blows everytime i turn the key to the on position.
Ran fine before now what? can't pull code with reader with key on or off.
06-14-2013, 01:00 AM
What is the fuse # that blows? #30?
The PCM can't diagnose primary power feeds directly so would be of no value looking for code.
06-17-2013, 09:41 AM
Think its #25 its the main fuse for the ign. 30 amp
pops the second the key hits on.
traced the harness for rodent or scraping and found nothing.
06-17-2013, 10:56 AM
Go back and look again. Also, tell us WHICH fuse box it's in.
07-05-2013, 11:39 AM
update
After much tracing of wire looms and plugs, It came down to bad slide switch
for the ign system. Contacts inside switch were cooked.
lostislandguy
15
03-08-2023 01:04 PM
aplummer
1997 - 2003 F150
16
04-30-2020 06:04 AM
Waterwise
07-18-2017 12:40 AM
imper
11-21-2010 03:14 PM
aleahey
Bronco II
08-06-2005 09:31 PM
