500 cfm too small?
500 cfm too small?
Im currently running a 500 cfm edelbrock carb. But im wondering if its too small? Here are my engine specs.what do you guys recommend?
390 bored over 30
Comp cams 270 magnum cam
Msd ready to run dizzy
Hooker headers
performer intake
Slightly ported c8AE-H heads
10.4 compression
3:50 posi
stock c6 and convertor
This is my weekend only hot rod truck so fuel economy is not a concern
390 bored over 30
Hooker headers
performer intake
10.4 compression
3:50 posi
It really depends on what rpm you want to run. if you stay below 5000rpm, then the 500 should be fine. The smaller carb will usually have better throttle response and mpg. if it is running good, I would leave it alone.
As a comparison, my old 77 had a 460 with a Performer intake, CompCams 268h cam and headers and ran fine with a 600 carb. It ran about the same with a 750, so I kept the 600 on it when I sold it.
joey390burnout
11-28-2011 08:24 PM
discman
08-25-2005 09:55 AM
Dyerstown
02-20-2003 09:56 AM
1965_ford_mustang
05-25-2002 12:50 PM
