Bleeder Valve Sizing Weirdness?
So just checking on something weird. I replaced the wheel cylinders on my '73 F100. The brake line fittings were 3/8in but the bleeder valves were 10mm. Doesn't this seem very strange? Also, when I look on Summit Racing, they list the bleeders for that application as 3/8in. As an aside, the new bleeders are cheap crappy metal that rounds very easily, even with the boxed end of a wrench. The old brass bleeders from the discarded cylinders seem much sturdier, and they were also fit by the 10mm wrench.
Additional question- are front caliper and rear cylinder bleeder valves all the same?
Minor Update:
I was in NAPA and asked what size bleeders the front and rear wheels take. Their parts book indicated 3/8 inch bleeders. I told them the parts they sold me were 10mm. They didn't believe me, pulled a wheel cylinder off the shelf, and they found out first hand that 3/8 wrench won't fit and a 10mm is a bit loose. Unfortunately, both 10mm and3/8 inch bleeder valves will screw into the calipers and cylinders. I think the quality control is just so poor the screws are supposed to be 3/8 but are oversized. Thoughts?
Also, how much does it matter? I ask because my front caliper bleeders came rounded and need replacement, but no one is sure what size to use.
Oh imported crap.
Oh imported crap.
Cummings Guy
07-19-2017 03:23 PM
Dave58
03-20-2006 10:47 AM
GregTruck
05-16-2005 09:33 AM
