86 6.9 blue smoke, rough idle and stalls - Ford Truck Enthusiasts Forums
Old 06-12-2013, 04:34 PM
John Clugston's Avatar
John Clugston John Clugston is offline
John Clugston is starting off with a positive reputation.
Friends 6.9 blows blue smoke, little black if you rev it. He is running wmo not sure what percent exactly at most 50/50 with diesel. He filters it with a paint strainer. I told him to switch to his front tank which is mostly diesel. Still doing the same thing. So he is going to try the diesel kleen trick overnight. It usually only idles for 10-15 seconds then stalls out. Changed fuel filter and does same thing. Im gonna help him tomorrow, what should we be looking for as the culprit? Truck has all original parts but mechanical fuel pump, just replaced several months ago. Truck has 92k miles. I got a 92 and 93 so I have spare injectors and injection pumps.
Old 06-12-2013, 04:46 PM
hairyboxnoogle's Avatar
hairyboxnoogle hairyboxnoogle is offline
hairyboxnoogle is gaining momentum as a positive member of FTE.hairyboxnoogle is gaining momentum as a positive member of FTE.
Could be air intrusion, but i dont think it would run that long. Try ATF/ diesel kleen and report back. When i was running WMO even over 50/50, it was dark grey not blue
Old 06-13-2013, 10:07 PM
Diesel kleen did not work. Ending up putting my one of my spare injector pumps on. Has much more power, but no its sucking in air somewhere. Going to start with replacing injector caps and return lines.
1985 6.9. Starts and idles but "runs out of fuel" when driving fish_19 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 07-03-2015 12:23 AM
what to look for when buying a 6.9 or 7.3 twister2gt Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-10-2014 11:23 AM
White smoke 1986 6.9 Freightrain Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-09-2014 11:25 AM
6.9 blowing white smoke and stalling out HELP HERMITTRUCKER Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 07-25-2009 12:16 AM
Blue smoke at idle IHdieselfan Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 21 04-05-2006 12:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
