2005 - 2008 Ford F250 Truck Super Duty Ignition Coil (Set of 8) for V8 5.4L - Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Old 06-12-2013, 03:39 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold1ATony is a splendid one to behold
CHECK HERE FOR GREAT PRICES 2005 - 2008 Ford F250 Truck Super Duty Ignition Coil (Set of 8) for V8 5.4L
FREE SHIPPING IN THE LOWER 48 STATES!!!
The ignition coil is a crucial part of your ignition system. It's function is to convert the 12 volt power of your vehicle's electrical system in to 35,000 or more volts. This produces a high intensity spark at the spark plug which then ignites the fuel in the cylinder. Coils in general will wear out over time. This will cause a misfire condition. In engines like this with one coil per cylinder you can diagnose a coil by putting a timing light on each one to make sure it is lighting the light consistently.
This coil over plug Ignition Coil SET features the following specifications:
Comes as a SET of 8
Brand New
Replaces dealer part numbers: 3L3E-12A366-CA, 3L3E12A366CA, 3L3U-12A366-BB, 3L3U12A366BB, 3L3Z-12029-BA, 3L3Z12029BA, DG 511, DG511
Built to strict quality control standard
Direct replacements
100% factory tested
This coil is a distributorless application. Sold as a SET of 8.
These are electrical parts and are all tested before they leave our manufacturer. This electrical item is not returnable; it is only eligible for exchange.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
__________________
Like us on Facebook
SHOP HERE FOR AWESOME BRAKE PAD AND ROTOR KITS - FREE SHIPPING
2009-2014 Ford F150 Truck 2 Inch Receiver Hitch (Curt) 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 02-16-2015 04:01 PM
2007-2014 Ford F150 Truck Power Heated Signal Puddle Light Upgrade Towing Mirror Pair 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 04-14-2014 02:14 PM
2000-2004 Ford F250 Truck Super Duty 4WD Front Brake Pad & Rotor Kit Semi-Metallic for Models with 1 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 01-30-2014 12:00 PM
1997-2000 Ford F150 Truck Manual Telescoping Upgrade Mirror Pair 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 12-03-2013 02:02 PM
2004 Ford F150 Truck New Body Style Power Heated Turn Signal Upgrade Dual Arm Towing Mirror with Chr 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 1 08-06-2013 10:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
