GOTTs mod debate
Old 06-12-2013, 12:22 PM
5.4mcnaughton's Avatar
5.4mcnaughton
5.4mcnaughton is offline
GOTTs mod debate
Well I haven't crunched numbers or done the mod myself, but I have read endless posts about the GOTTs mod and the benefits it will bring to acceleration and power, but I have read disturbing posts saying " what were ford engineers thinking reducing the intake diameter... Obviously they had their heads up their asses"... Now I work in the engineering field on nuclear reactors just as a background, and a very very basic physics concept is area goes down velocity goes up... So again I have not done the numbers... But does just opening up the intake 1 inch really going to make that big of a difference, especially when you are still restricted by the diameter of the throttle body anyway I feel changes would be minimal at best, and I feel like a placebo effect has taken place on many people's feeling towards the power increase... I understand its only ten bucks to do this modification but still just wondering
Old 06-12-2013, 12:45 PM
Gundown64's Avatar
Gundown64
Gundown64 is offline
I think you are probably correct. The gains are definitely minimal at best and most likely only seen in the 4000+ RPM range, which most people rarely reach. Placebo effect is probably definitely prominent. However, like you said, it's a $10 modification and 30 minutes of your time so I say do it anyway. I have it done to mine, but I didn't really feel much. I mean, I thought I did slightly when I first installed it, but again, placebo effect was probably a thing.
Old 06-13-2013, 04:47 PM
60DRB's Avatar
60DRB
60DRB is offline
Who knows? We need an aerodynamic engineer to chime in...to discuss Bernoulli's principle. Maybe then we'll have a realistic answer.
Old 06-13-2013, 07:58 PM
5.4mcnaughton
Lol yeah I do not want to go through the madness of even trying to obtain the figures to plug into bernoullis...
Old 06-17-2013, 11:16 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
Makes sense, that's why people don't throw a 5" exhaust on, you lose velocity at real world engine rpms.
Old 06-17-2013, 11:40 AM
dfishrmn88's Avatar
dfishrmn88
dfishrmn88 is offline
Yes, I think you are right about slight improvement mostly at high acceleration. Passing on the highway, etc. I'm not a drag racer so I can't comment on that end. I installed this years ago before I ever heard of GOTTS. Not sure were I got the idea but I think it was worth it. I have a little different version then some of the pics I've seen and it does'nt look much different from factory.
Old 06-13-2020, 12:53 AM
BillSF9c's Avatar
BillSF9c
BillSF9c is offline
> We need an aerodynamic engineer to chime in...to discuss Bernoulli's principle. [/QUOTE]
No carb, No Bernoulli to it.
You are.only allowing air draw to be less restricted. Think, high flow air filter. It is not of course, but as the Gott's Mod is still in series with your filter, the effect is the same. You go from ~3.14 sq in to ~7 sq in. Flow ABILITY might increase by the sq rt of 2, or 1.141... or resistance be the inverse, 0.7 of before... but only on that section, which is still in series with the filter, manifold, etc. Let's dream that overall we get 1% economy, or HP at top end rpms. Ford would have juggled CAFE against cents for more rubber and plastic and bigger dies and molds. CAFE is at lower rpms - not much effect w this mod. But it sounds FUN! 1% of my year's gas is $20. Breakeven in 2 years? LOL!
truckrider814
02-16-2014 03:53 PM
jg96powerstroker
07-16-2011 07:42 PM
caleb90
06-13-2009 01:34 PM
DieselBeast01
19
09-09-2008 01:09 PM
97 HD
07-16-2007 01:25 AM
Quick Reply: GOTTs mod debate
