temp gauge problem - Ford Truck Enthusiasts Forums
temp gauge problem
Old 06-11-2013, 11:07 PM
gjwniflst gjwniflst is offline
gjwniflst is starting off with a positive reputation.
temp gauge problem
I believe I posted in the wrong section before! Sorry, new to site.
I have a 1960 F100 that someone transplanted with a 1957 312 Yblock. The truck has an aftermarket gauge set and the standard dash gauges/idiot lights.
My problem is in the temp gauges. The aftermarket gauge reads a safe temp + - 180. The location of the sensor for the aftermarket is near the #8 cylinder intake. The dash gauge pegs the hot line in about 10 to 15 minutes of drive time. That sensor is located on driver side block just above oil sending unit.
I have used an infrared temp probe (laser) and get basically the same readings as the gauges, respectively.
Could I be reading oil temp on the dash gauge or do I have a water flow restriction in the lower part of the motor?
Old 06-12-2013, 09:26 AM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
I think the location of the dash gauge sender is where a petcock is usually installed to drain the block coolant on driver side. So it would read water temp.
Old 07-16-2013, 09:13 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Normal location is in head, behind intake by #8 (driver's side, or -left- at top rear of motor assembly). There is an oil pressure gauge location on side of block near oil filter location. Oil temp could easily climb above water temp. Perhaps you could pull stock sensor and see if water or oil comes out?
Got picture? That may help.
Aftermarket water temp gauge ol_red92 1987 - 1996 F150 & Larger F-Series Trucks 7 02-25-2015 06:48 AM
temp gauge problem gjwniflst 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 06-24-2013 08:06 PM
351 extra temperature gauge andyman7931 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 06-17-2009 10:02 PM
Aftermarket Mechanical Gauge Installation Pele Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-25-2007 09:27 PM
1964 dash gauge cvr jaymorris 1961 - 1966 F-100 & Larger F-Series Trucks 9 01-31-2007 07:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
