2007 Expedition - water on passenger floorboard during rain only!!! - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 06-11-2013, 01:08 PM
99powerstrokedF250 99powerstrokedF250 is offline
99powerstrokedF250 is starting off with a positive reputation.
So I bought my wife a 2007 Expedition a couple weeks ago, and she absolutely loves it for driving our son around...except that we've noticed that the passenger floorboard gets wet when it rains. We have not noticed it doing it with the AC on as an old thread here suggests, so I'm not sure that it is water condensing from that, I'm pretty sure it is coming in from the outside (though I will be investigating that little drain tube to make sure). Any suggestions on where this water may be coming in from? I've had the carpet up and the glovebox out, but I haven't really had time to dig much further than that. I've thought about the windshield seal but I would think I'd see something from the outside.
Does the HVAC intake under the cowl have any kind of trap or door that is supposed to keep water out?
Any help steering toward the right direction would be awesome.
Thanks in advance.
Old 06-11-2013, 02:24 PM
rexster314's Avatar
rexster314 rexster314 is online now
rexster314 is starting off with a positive reputation.
Do you have a moonroof? If so, check the drain tubes, they tend to stop up.
Old 03-15-2014, 11:51 PM
Thought I'd update - solved this issue. No moonroof, we have the rear entertainment system.
Turns out there was a grommet missing under the cowl - so I had a 1" hole that just let water pour in. Plugged that hole and the problem went away immediately.
Leak in Cab of Truck. ajbrown208 1999 - 2003 7.3L Power Stroke Diesel 4 03-29-2016 11:07 AM
2010 F150 Lariat wet passenger floorboard Bazinga_al 2009 - 2014 F150 9 04-14-2015 05:47 PM
Water in floorboard??? BackwoodsBum 1999 to 2016 Super Duty 10 03-20-2015 05:37 PM
Leak SolusUmbra Ranger & B-Series 9 03-13-2015 11:35 AM
2002 Expedition Heater Core Swap changetheworld 1997-2006 Expedition & Navigator 5 01-11-2014 03:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
