Ranger 3.0 fuel pressure problem. Need help please. - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-11-2013, 12:18 PM
Bsnith Bsnith is offline
Bsnith is starting off with a positive reputation.
Question Ranger 3.0 fuel pressure problem. Need help please.
I have a 2003 Ranger edge 3.0 flex fuel 183,000 miles. I have been having a misfire problem, only at idle, always cylinder 3. Replaced the fuel filter. Just replaced fuel pump assembly. With the old pump my fuel pressure was 49psi key on engine off, and running at idle it was 59psi with a shaky needle. With the new pump, when I turn the key on it jumps to 60psi then imedietly drops to 49psi, when the pump shuts off. Running it is at 60psi with steady needle. Koeo the pressure holds good at 49psi but does slowy decrease, about 5psi in 15 minutes. What would be causing the pressure to drop to 49psi? I am checking pressure at the fuel rail. Pressure according to the haynes manual should be 60-65psi koeo and the same while running at idle.
Old 06-11-2013, 12:41 PM
Furyus1's Avatar
Furyus1 Furyus1 is offline
Furyus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputation
Welcome to FTE.
It's just a thought, but I would check the fuel pressure regulator.
Old 06-11-2013, 12:43 PM
The regulator is part of the assembly I replaced.
Old 06-11-2013, 02:03 PM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
Now for the bad news. If you used an Airtex fuel pump module that could be your problem. The hose that goes from the return to the pressure regulator needs a clamp on it if it didn't come with one. I have had a lot of problems with that brand of pumps on the rangers here at work. I hope this helps you out some.
Old 06-11-2013, 02:51 PM
I used a Delphi. Could that hose still be an issue?
Old 06-12-2013, 08:17 AM
pawpaw pawpaw is online now
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
With the mileage on this ride, your having replaced the fuel pump & still a cyl 3 misfire code, then the rough idle, fuel pressure leaking down/falling off after shutting the engine down, maybe put a leaky #3 cyl fuel injector on your suspect list.
Use your stethoscope, or rig one from a broom handle, long screwdriver, length of tubing, or rubber hose, one end to the suspect, the other to your ear to try & determine if #3 injector sounds different than the others.
If you come to suspect the #3 fuel injector has a runny nose, before replacing it, or removing for cleaning, maybe consider trying a 20 oz dose of Chevron Techron Concentrate Plus in the tank at the pump before filling up (so you get good mixing) & fill up with Chevron, Texaco, Caltex, or now Shell, as those fuels already have some PEA in their ad pack, so the additional 20oz dose of Techron will raise the treat rate 10X over pump gas alone & will usually get the tidy up job done in one tank. Run most of the treated tank out before refilling, or treating the second tank if you think it needs another dose.
More thoughts for consideration, let us know what you find.
Old 06-12-2013, 08:57 AM
Thanks for the suggestions. I was thinking it may be a leaking injector, since its always the same cylinder misfire that I get on the cel. I just wasn't sure how to check if it was leaking. I did listen to it with a screwdriver and could hear it working. I will let you know when I figure it out. Thanks again and I'm open to any more ideas until I get it fixed.
Old 06-12-2013, 11:06 AM
Did the #3 injector sound different that the others????
Old 06-12-2013, 04:41 PM
It did sound different. Sounded like it was clicking slower than the other ones. Also I disconnected the electrical connector while it was running at idle and didn't notice any change in the idle. Im just going to replace that injector. I'll let you know if that fixes it.
Old 06-12-2013, 07:11 PM
Several things could cause a problem with #3 injector. Before replacing the injector, check its resistance. It should be between 12 & 16 ohms. All of the injectors resistance values should be very closely matched within that range. So measure all injectors resistance with your multimeter & if you do replace #3, make sure the replacements resistance value is closely matched with those in the vehicle.
If the injector checks out ok, at KOEO measure B+ voltage at its electrical connector to make sure its getting full B+ to operate. Then back probe the B+ connection with the engine running, to make sure you have full B+ under the load that the injectors coil puts on its circuit.
If that's ok make sure the computer #3 ground switching driver is doing its thing, as excessive electrical resistance causing a voltage drop to the injector, or excessive inline resistance between the injector & the ground switching driver will corrupt things.
Old 06-12-2013, 07:23 PM
Ok. I'll check that as soon as I get a chance. Probably tomorrow morning.
Old 06-12-2013, 07:57 PM
With the idle not changing when you disconnected the #3 fuel injector electrical connector, it kinda sounds like it has a runny noise & is leaking enough to keep #3 cyl running well enough not to affect idle rpm much.
It's your money, but if the injectors electrical resistance checks out, I'd maybe first try the Techron treatment & see if it'll make a difference. It's a lot less expensive than a new fuel injector. If the injectors have never been cleaned, the Techron could make a noticeable difference in driveability & could improve mpg by tweaking all the injectors spray pattern. It'll also tidy up the intake valves, piston crowns & combustion chambers of deposits. The autoparts stores have been running it on a bogo deal lately, so it would be $6 & change for one bottle & if that didn't do it, the other one would likely finish the job.
OR, just remove the injector & try cleaning it. Let us know how it goes.
Old 06-13-2013, 08:58 PM
I checked the resistance on the injectors. They were 12.3-12.6 ohms. The voltage at the connectors was 12.06-12.11 volts with koeo. I also replaced the #3 injector and it made no difference. The fuel pressure still drops off. I still need to check the other things you mentioned. Just thought I'd give you an update.
Old 06-14-2013, 06:47 AM
OK, good feedback on the injectors resistance value range.
What's the new injectors resistance value in ohms & did it sound the same as the old one???? Was the old fuel injectors tip wet with fuel & or dirty/varnish/carbon, around its tip????
Edit: After replacing the #3 fuel injector & erasing the misfire code, do you still have the rough idle & misfire code returning for #3 cyl??? With the mileage on these injectors, you could have more than one injector with a runny nose!!!! Keep us posted on your KOER voltage drop reading for #3 injector.
Old 06-15-2013, 05:21 PM
The voltage at the connector while running was 13.7 volts. The resistance on the old injector was 11.99 ohms. The tip looked good. Still get the same rough idle and cylinder 3 misfire code. If another injector is leaking could it cause cylinder 3 to misfire? I have never had any other code come up, always cylinder 3 misfire. My code reader can show live data, if that would help. I dont know what to look for on there. Fuel pressure is still low with koeo. I'm really lost on this one. I may have to just take it to the dealer for diagnostics. I can usually fix things myself, but this ones got me stumped.
Fuel Pressure Help failsatheals 1997 - 2003 F150 5 06-21-2016 10:03 PM
Installed fuel pressure gauge evan1242 6.0L Power Stroke Diesel 13 07-14-2015 06:24 AM
Long start 1991 Ranger 3.0 wtroger Ranger & B-Series 14 03-17-2015 09:57 PM
2003 4.0 long start fuel pressure problems Gary E Ranger & B-Series 4 06-03-2013 03:18 PM
Fuel Pressure Test Results - Seeking Interpretations & Recommendations PaulDH 1987 - 1996 F150 & Larger F-Series Trucks 16 05-22-2010 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
