2001Ranger 3.0 top dead center
Old 06-15-2013, 08:11 PM
Ythomas's Avatar
Ythomas
Ythomas is offline
Question 2001Ranger 3.0 top dead center
How do I find top dead center, I'm working alone.
Old 06-16-2013, 10:49 AM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
If all you want is tdc, just line up the timing marks on the crank pulley with the pointer. But if you're needing tdc compression stroke, pull the #1 spark plug, place your finger over the plug hole, using a ratchet turn the engine, the correct way, till you feel compression, then continue turning till the marks line up.
jpyles
11-09-2015 03:45 PM
Gil Chesterton
03-16-2006 02:14 PM
dilbone56
01-22-2005 01:13 PM
beastybronco
Electrical Systems/Wiring
20
08-13-2004 02:05 PM
spshultz
05-13-2002 07:17 AM
Quick Reply: 2001Ranger 3.0 top dead center
