"Brutus" 1956 Ford F-100 - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
Old 06-11-2013, 07:15 AM
jwatson1969's Avatar
jwatson1969 jwatson1969 is offline
jwatson1969 is starting off with a positive reputation.
Here we go! Picked up Brutus after much hesitation to part with the money for him even though I felt he was well worth the money I paid. He has a 302 engine that ran, even though I never heard it run when I bought it, with an auto transmission and a rear end out of a 74 torino and gear and pinion out of who knows what. An old fella, 87 years old to be exact, that had bought the truck after retirement age and clocked at 125mph in it, YIKES!! that almost cried I think when we tired him off down the road. Soooo, Mr. Brutus didn't like being woken up after sleeping for over 10 years. We did know about him not having brakes but circumstances unloading and not quite being prepared send me and Brutus for our first joy ride together down my back yard where we parked him through my 4x6 trellis and the kids swingset...yes...through. Soooo, we will start the project here at this point I do believe. Meet Mr. Brutus....
Old 06-16-2013, 02:51 PM
Brutus resting before I got him.. April 25th, 2013
a '65 or '66 bed on him I was told
Solid metal or wooden slats?...hmmmm
Old 06-16-2013, 03:02 PM
Brutus comes home and we take our first joy ride into the back yard and park through the trellis and the kids swingset
Old 06-16-2013, 03:13 PM
Brutus gets straightened up and the swing pulled out from under the front end
Brutus inspires...the next day after coming home, his cousin "Studee" comes out of the barn next door after sleeping quite a while and gets a bath
Brutus draws first blood...I'm sure you can all relate...the first of many times I'm sure
Old 06-16-2013, 03:20 PM
June 1st, 2013...guess the first place to start is what everyone else probably does too...start with the bed
Old 06-16-2013, 03:32 PM
Bedless!!
Had to park the bed upside down beside the building for the moment...didn't realize the sides and front pieces were welded together...cutting wheel in the future maybe?
Old 06-16-2013, 03:50 PM
Old 06-16-2013, 03:52 PM
Brutus post carb kit...purrs a little more and don't have to keep the gas on to keep him at idle...oh, and I made a point to leave some room near the exhaust...didn't see any smoking....YAY!
Old 06-16-2013, 04:48 PM
think we've got most everything off from the cab back...
time for some sanding or wire brushing or blasting....what should i cover it up with?...rust inhibitor?...primer?...undercoating?
Old 06-21-2013, 07:12 PM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Cool project! Looks like you've got a great truck there. Sounds like you've had some fun with Brutus so far! Do the kids get a new swing set?
Your 302 sounds good! That carb kit worked it's magic.
Keep up the good work and keep posting your progress.
Old 06-30-2013, 04:20 PM
June 29th, 2013
kids have outgrown the swingset weightwise so might make them one...not sure yet....tried out the POR-15 product this weekend...goes on and dries hard as a brick....and they weren't lying about it not coming off your hands....i was able to get it off/most of it with some scotchbrite pad though...ouch!
Old 07-01-2013, 02:34 AM
It's looking good.
When working with POR-15, gloves are your friend!!
Old 07-30-2013, 10:08 PM
a little primer and black paint sprayed over the por-15 and leaves wire brushed a little then sprayed and put back on....new bushings and pins and hangers...left off the bottom three leaves on each side....not sure that it will drop it much other than the thickness of the leaves themselves but every little bit counts ...time to clean on the rear end next i guess
Old 04-07-2014, 01:41 PM
very little progress going on here...am thinking a bit of hugger orange for Mr. Brutus eventually
Finally have time to do some TLC El_Coqui Excursion - King of SUVs 39 12-08-2015 03:50 AM
An offer I couldn't refuse ... Brutus is headed to upstate NY CelticOne 1973 - 1979 F-100 & Larger F-Series Trucks 16 11-21-2015 01:31 PM
vin help brutus67 1967 - 1972 F-100 & Larger F-Series Trucks 3 05-09-2015 06:59 PM
ECT live data = -160C??? brutus_jr 1999 - 2003 7.3L Power Stroke Diesel 15 09-10-2014 10:04 PM
tranny swap brutus67 1967 - 1972 F-100 & Larger F-Series Trucks 5 10-13-2013 12:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
