Diesel mechanic shop near Danbury
Picked up a 96 PSD and since the winter its been having starting issues. When it was cold it would not start at all. Once it got warmer if I spray a little starter fluid in the air filter it starts up and runs fine, but wont start without the starter fluid. I want to play around with it a bit to see if I can fix it, but if that fails can anyone recommend a good diesel shop near the Danbury area, I don't know much about diesel and generally hate going to mechanic, can't trust many of them. Thanks for the help.
Stop with the starting fluid immediately before you ruin that engine.
Test to see if you have power to the large post on the drivers side of the glow plug relay.
The glow plug relay is the large relay just behind the fuel bowl to the left if you're standing in front of the truck looking into the engine bay.
I was hesitant to use the starter fluid but read through some forums and picked up one with upper cylinder lubricant and only gave it a quick 1 sec shot. I've only done this about 4 times since December.
I've seen 7.3s ruined by starting fluid and the compression #s aren't pretty. I'd be willing to bet the problem is glow plugs or glow plug relay. Most likely the relay.
Dezl Newbie
28
01-05-2017 06:59 PM
