rear axle leak??
rear axle leak??
Hi all, 1979 f350 4wd- while dropping my fuel tanks this weekend i noticed some fluid leaking from the back side of the hub? Question is what am i looking at replacing. . . When i started looking for rear axle seals , 2 came up . A rear hub seal and an inner axle seal? Which one or both , as long as i have it all apart. Is one more complicated than the other to replace . Thanks for any info.
By your description it is the rear hub\drum seal. The other seal is the outer axle seal. That is the part with the bolts that you can see in the center of the rear wheel. Replace the inner seals on both drums because they typically wear the same. Also, check your axle vent, that is the square piece of metal mounted on your axle housing. It is supposed to have a rubber hose connected to it pointing up towards the bed of the truck to keep debris out. Make sure both the metal and hose are clear of obstructions or the housing can build up pressure and blow the new seals.
If the surface on the axle housing where the wheel seal rides on is grooved, they make repair kits.
If the groove is slight, take some Emory cloth to it.
I'm an Idiot, all my life I have used only a hammer and large flat-blade screwdriver to remove or install the axle nuts.....
Eric Kropp
10-28-2014 05:33 PM
pacrewchief
06-09-2012 09:12 AM
