Rear Mount Turbo 1997 4.6L - Ford Truck Enthusiasts Forums
Old 06-10-2013, 04:12 PM
78Jimmy 78Jimmy is offline
78Jimmy is starting off with a positive reputation.
I've been reading some of the posts and have a few questions regarding this setup.
Background on the truck. Low km 1997 4.6L Expedition, stock engine with the following upgrades; Throttle Body Spacer, K&N, SCT programmer, and just ordered headers.
I'm looking to reduce the engine load on my 4.6L with the addition of a Turbo, hoping for a little MPG gain as well.
The rear mount is intreguing as it's out of the way, and will give me that little extra. Currently when I tow my trailer I have a pretty good engine load, and would like to reduce it.
Goals - As this is a stock bottom end, I am looking for 7-9 psi, and a reliable truck. Not something that will be used for racing. I tow a trailer, and haul the family around.
So question period;
- When you rear mount a turbo, is it possible to route the intake up, as I assume the closer the better, what is the drawback?
- Skidplate? I live in Canada, and am concerned that snow, debri will hit the Turbo, or the snow will crack it.
Cost is a concern, so I will be building this myself. So, reference material or recommendations are appreciated.
Old 06-19-2013, 09:04 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust Ziegelsteinfaust is offline
Ziegelsteinfaust is starting off with a positive reputation.
I want a turbo engine bad, and I have looked into the rear mount. Luckily I got to meet a couple of people who have it along the way.
The lag is not that bad just slightly more then a normal set-up.
As for water in the intake you can put a filter sock over it, and that keeps water from just getting it. Plus also sand and excess dirt.
Turbos are designed for being hit with water, and not crack. If you have a turbo Saab water will still hits the turbo, but its turbo is a few hundred degrees hotter then a rear mount.
I don't know enough of how snow collects under a vehicle to say anything, but you could probably block off an area sufficiently for the turbo.
Lastly put it as close to you engine as possible. This way you reduce lag greatly by keeping the thermal efficiency high.
Old 06-23-2013, 05:45 PM
stoffer's Avatar
stoffer stoffer is offline
stoffer is starting off with a positive reputation.
lag, has a lot to do with sizing (A/R, pipe, turbo, motor, etc)
Old 06-26-2013, 08:20 AM
Good to know.. Yes, sizing will be a challenge.. I hate buying things twice due to mistakes..
With a turbo system, would it be better removing the cat's? This wouldn't really allow me to get the turbo closer, however would free up the exhaust system.
Noise and performance issue Murphy IRE 1999 to 2016 Super Duty 4 09-24-2016 10:48 AM
1997 Expedition and Toy Hauler Towing? MPDano 1997-2006 Expedition & Navigator 45 02-10-2016 07:36 AM
Modular engine guys may want to see this. Bently_Coop 1999 to 2016 Super Duty 24 01-05-2016 01:02 PM
2010 F150 Bent Fuel Pump - Part 1 JTF150 2009 - 2014 F150 21 09-22-2014 09:31 PM
1997 Ford 4.6l 2v Upgrade 78Jimmy Modular V8 (4.6L, 5.4L) 0 08-31-2014 12:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
