What weight gear oil for trans and rear axle? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-10-2013, 05:10 PM
imabass imabass is offline
imabass is starting off with a positive reputation.
87 L8000 7.8 Ford Diesel. 5 speed and single rear axle gear (no high/low). 39,000 GVWR.
I recently purchased the old fire truck and I have done a lot of work getting it ready for the road (tires, brakes, oil pan gasket, belts, batteries, etc.) Since there was no service record book I am replacing the fluids and doing many maintenance items so I have a good base line.
What weight gear oil for transmission and rear axle? 85w90? 140? Will be used as farm truck and infrequently. Where can I find it in the 5 gal bucket? I went to the local farm supply and they only sell it in the quarts.
Any recommendations for a gear oil pump for filling?
Old 06-10-2013, 06:30 PM
did some searching and looks like 50wt oil.
Old 06-11-2013, 12:20 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
50w was recommended for some older 4 speeds, and perhaps the 5s in older trucks.
It was never recommended for differentials.
Can you post your VIN and the info off the warranty plate? Lots of info available there, including the make of your trans.
A bit on trans and diff oils:
Synchromesh Manual Transmission Lubricants - Bob Is The Oil Guy
Old 06-11-2013, 05:32 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
No VIN has codes related to trans or axle, both codes printed on Certification Label (1980 to date). Stamped on 1961/79 Warranty Plate and 1948/60 Rating Plate.
Old 06-13-2013, 09:13 PM
merlynr's Avatar
merlynr merlynr is offline
merlynr is gaining momentum as a positive member of FTE.
fyi This number has helped me in the past for lubrication questions.
800-237-8645 I think it's Shell Oil Co.
Old 06-16-2013, 10:57 PM
Unimogr's Avatar
Unimogr Unimogr is offline
Unimogr is starting off with a positive reputation.
Eaton trans and axle? They have PDFs posted on their axles w/ lube info.
http://www.dana.com/wps/wcm/connect/...df?MOD=AJPERES
They have many more available on line. Search your needs.
Rear differential gear oil 66with352 1997 - 2003 F150 1 10-28-2016 10:54 AM
T19 Transmission Fluid quakerj 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-21-2013 03:21 PM
Heavier gear oil weight in diff? andrewasl 1967 - 1972 F-100 & Larger F-Series Trucks 4 05-01-2011 10:15 PM
Front and Rear Axles----Differential fluid--what Weight? Ford Fx4 1987 - 1996 F150 & Larger F-Series Trucks 10 03-22-2010 06:07 AM
weight of gear oil? mike L Oil & Lubrication 5 03-30-2006 02:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
