Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
'71 Ford F600 -Front Diff
Old 06-18-2013, 05:45 PM
JoeD500's Avatar
JoeD500
JoeD500 is offline
Hey all,
I have a front axle/diff out of a '71 Ford 600 which had the NAPCO 4x4 power pak. I have pulled the front axle for servicing as I have found it does not seem to work and I would like help with troubleshooting the problem.
The model is a Napco 38508 with manually lock hubs (with I think a 7.20 gear ratio). The T-Case engages and works- so that is out of the equation. With the front axle out and drive shafts removed, I can freely spin the input yoke on the differential.
I have turned the hubs to 'lock' but still get no resistance from the tires trying to spin as they should. Also, as I wheel the assembly around the yoke does not spin - as it should. However, one of the hubs manual lock seems to not be as engaging and does not spin freely as the other. I am not sure if this is just from sitting or internal problems.
So; what could be some probable causes for this and the appropriate methods of repair. I am also aware that parts are rare for these axles, but would like to make efforts to repair it myself or TRY to locate the right parts before scraping it & looking for something else.
Any input is as always; much appreciated.
Joe.
Old 06-18-2013, 10:25 PM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
... I would bet the hub is the issue... are the springs worn... and did the PO re-assemble it correctly ..with all the parts...
hubs..lets see
go over to the napco guys.. bet they can help
<cite class="bc">www.napco4x4.org</cite>
Miescha
1999 to 2016 Super Duty
15
04-14-2022 07:49 PM
WhiteHorse04
11-14-2011 11:59 AM
ssknightrider
08-23-2010 09:44 PM
campbell6661
11-15-2008 07:44 PM
jwhitetail
07-21-2008 03:59 PM
Quick Reply: '71 Ford F600 -Front Diff
