1987 f250 cruise control inop.
Old 06-10-2013, 12:12 PM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
Hello I have 1987 f250 6.9 diesel 4sp manual trans 4x4 the cruise control stopped working the fuse is good i swapped out the vacuum operated component under the hood with a known good part and still does not work no lights or anything work for the cruise thanks for any help.
Old 06-11-2013, 03:44 PM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
How does the power get through the steering wheel i was told this year of truck doesnt have clock spring??? HELP!!!!!!!!
Old 06-11-2013, 05:49 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,081 Likes on 2,151 Posts
spring pins and contact plates under the steering wheel.
make sure the clutch switch is working properly. if the clutch is not all the way up, the cruise will think the clutch is depressed and not work.
Old 06-12-2013, 04:18 PM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
Thank you Tom will look at those i did replace the turn signal switch the ond one had to springs the new one only had 1 spring does that matter?
Old 06-12-2013, 05:22 PM
tjc transport
i ain't rite
turn signal switch should not have any effect on cruise.
Old 06-14-2013, 12:29 PM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
Tom where are these spring pins the only thing i can find that appears to be spring pin is attached to the turn signal switch a metal pin and it appears to have a spring under it only 1 of them and another hole where looks like there should be another one but there is not thanks for your help.
Old 06-14-2013, 01:26 PM
tjc transport
i ain't rite
not sure, it has been at least 15 years since i had a column apart.
Old 07-02-2013, 12:16 PM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
Ok I ruled out the clutch pedal im leaning towards the control buttons does anyone know how to test them thanks
Old 07-18-2013, 11:23 AM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
Still not sure what my next step would be i hate to just start throwing parts at it any other ideas out there? thanks for any help.
Old 07-18-2013, 12:22 PM
F150xlt's Avatar
F150xlt
F150xlt is offline
The cruise control /tilt wheel turn signal switch is different from a truck with no
cruise.
Should be two spring loaded contacts. Yellow wire and a Dark Blue wire.
If you look at the back side of the steering wheel you'll see the cam surface they
make contact with.
There's actually two other metal spring loaded pins that make contact with the
inner most ring. They provide a ground signal path..They are not part of the turn signal switch
assembly.
Old 07-19-2013, 02:14 PM
J5BAIL's Avatar
J5BAIL
J5BAIL is offline
Awesome thank you i will go take alook thanks for the info.
Corvus
1999 to 2016 Super Duty
06-02-2010 02:18 PM
tpolley
06-02-2008 08:31 PM
tlbranth
02-11-2004 08:54 AM
jasonvt
Bronco II
07-24-2003 09:02 AM
F350flatbed
Electrical Systems/Wiring
06-01-2003 10:43 AM
Quick Reply: 1987 f250 cruise control inop.
