gem Moduler 1999 Ford F350 Super Duty 5.4 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-10-2013, 12:18 PM
langdon langdon is offline
langdon is starting off with a positive reputation.
Hi guys! 1)My fuel pump was not working so I replaced the pump it did not work!
I checked power running to interria switch I get 7volts! (I connected a battery pack to wire running to fp at interia switch, pump works!) I also have checked all relays and fuses in dash and engine department boxes! I also removed and checked to make sure I was getting power to relays! I did this several times they check out! But, at the fuel pump relay under the dash behind the radio I'am getting no power! ( A side note the flasher relay is in the same little box and it works fine!)
2) Ok now I put 2+2 together see my wind shield has a leak and my radio stays on after key is off and I get the buzzing noise rather my keys are in or not plus no power to the wiper water pump relay so this is clearly the Gem Modular?
I would like to know 3 things!
A) Can any service garage test my Gem or does it have to be a ford dealer?
B) Could no power at my Fuel pump relay be related to my Gem?
C)would you risk buying a used one from a local selvage yard or ebay?
Thank You, Mike
Old 06-10-2013, 08:27 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
92f150I6 is gaining momentum as a positive member of FTE.
Just a thought. I had to replace a GEM in an explorer and it needed to be flashed by a dealer to work properly. If you replace your GEM you may have to do the same.
Old 06-10-2013, 09:27 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
It's more likely the fuse box than the GEM since the GEM module has nothing to do with the fuel pump power.
Might be both, though. You'll have to sort through the symptoms by priority and see where you end up.
Old 06-11-2013, 09:38 AM
thanks for your reply! I have taken out the fuse box and gem. the terminals on fuse box are corroded a little bit i'am cleaning those. I have also sprayed "QD Electronic Cleaner" (produced by CRC) in the female connectors! Is this the most effective way of cleaning the connectors! I.E. would you suggest a better cleaner or is the one I have ok? Also I open the gem box and visibly there is no scorching or discoloring. Is it ok to open fuse box and could you tell by looking at it rather to replace or not? i.e. Looking for extensive corrosion?
Also I just found a fuse box off a 99 ford 250 super duty with 4x4 would that work on a 350 with 2wheel drive?
87 F250 460 fuel tank selector relay location? jumbofordman 1987 - 1996 F150 & Larger F-Series Trucks 2 02-02-2015 06:15 PM
No Pwer to Fuel Pump relay jdawest1 1999 to 2016 Super Duty 13 12-17-2014 04:34 PM
Parking lights won't turn off. Tried everything!! p51man Electrical Systems/Wiring 3 09-26-2013 07:49 PM
Now power to 4x4 relay,bad GEM? jprix 1997 - 2003 F150 7 08-29-2013 10:57 PM
Electrical Issues, Need help big time GreenTerracePSD 1999 - 2003 7.3L Power Stroke Diesel 19 06-26-2013 06:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
