2010 F350 - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
2010 F350
Old 06-10-2013, 08:54 AM
rnxlf250 rnxlf250 is offline
rnxlf250 is starting off with a positive reputation.
2010 F350
Hi All,
I am looking at upgrading from my 02 F250 to a 2010 F350, Does anyone know of any major problems or issues with the 2010 model or the 6.4L engine for that matter? Also what is the fuel economy like on the 6.4L Thanks in advance,
Matt
Old 06-10-2013, 08:23 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
I moved your thread to the Aussie chapter mate.
I can give you the quick run down, but you are best served to go to the 6.4 forum and read up.
In stock form, they are fuel pigs. They had the first generation of advanced emission systems with diesel particulate filters, that had active regeneration - this essentially means every 1500-2000km, it will dump a whole lot of fuel through the system to burn out the particulates caught in the particulate trap. This means that a lot of them average in the 16+ l/100km mark.
The not so bad thing about that, is that with a tuner, you can get rid of that crap (emissions system) and really improve your fuel economy. And they have a fuel system that will mean that you can have around 650hp with just a tuner/exhaust - and they don't sound like an old semi truck at idle like your 7.3 will (could be good or bad, depending on your perspective)
Other issues they have had are gunking up of the engine/turbo's from EGR etc. cracking radiators etc.
The Auto trans fitted to them is a lot better than the one fitted to yours, and the rest of the truck is quite a bit nicer as well.
They fixed a lot of the issues with the 6.0l with the 6.4, but not all of them. (Head gaskets etc. are much better, but not fool proof if you turn the tuner up)
The other thing of note, is that if you need to do something serious to them, it will most likely be a cab off operation.
Hope that helps a little.
Old 06-11-2013, 04:57 PM
Thanks big f350, I read through pages and pages of stuff on them in other threads and figured i would ask here too. I think i might pass on it as i recently found a guy that had one and he like you said had the cab off and the costs blew out beyond belief......might wait to afford a MY12 model.
Old 06-11-2013, 05:18 PM
To be honest, I would wait out as well. The 11+ have proven to be more reliable (by the looks of it), and get a lot better fuel consumption.
If you have access to a 2 post lift (to get a cab off), and aren't afraid of spinning spanners yourself, instead of paying $100+ an hour in labour, it still might be worthwhile looking at.
Old 06-11-2013, 06:21 PM
Nkelly's Avatar
Nkelly Nkelly is offline
Farkall User
Nkelly is gaining momentum as a positive member of FTE.Nkelly is gaining momentum as a positive member of FTE.
Was thinking of doing the same importing a (2008-2010 model) had a discussion with clay(riffraff) about running the truck via his workshop,he was going to do the DPF and EGR delete for me...
But now im thinking putting it off for another couple years and then going after a 2013 model love the dash on the 2013 with the hump in the middle with the big touchscreen audio/GPS/rear view cam so on ..
I also like the chevy Silverado sssshhhhhhh don't tell brian,but the front end looks like a nightmare if you want to do a suspension lift
Old 06-12-2013, 01:50 PM
I am looking at getting a 2011 SRW F350 Crew Cab long bed. I am in a fortunate situation that if I hold it for 12 months over here, I won't need to pay GST on importation, and I only need it to pass a road worthy (not be fully ADR compliant) so RHD conversion is cheaper. I am looking for a truck now, and will hopefully find a place to do a conversion here in a month or so. I'll write up my experience.
The Chevy/GMC I ruled out, because no solid front axle. I do really want a manual trans, and for that reason alone a 2010+ Ram was on the shopping list, but it looks like you need to rip all the emission stuff off/run a tuner to get reasonable milage, the clutch needs to be upgraded if you do run a tuner, and a lot of the other aftermarket stuff is more difficult/expensive to find for the Ram than the F350 - not to mention they don't come stock with a "proper" rear locking diff like you can get on the 2011+ Fords. I would like to have a Cummins engines for getting parts in Aus however (and finding a mechanic to work on it if I can't be arsed), and it actually has some room in the engine bay to spin a wrench.
Old 06-12-2013, 05:07 PM
Nkelly's Avatar
Farkall User
Yep the chevy front end turns me off a bit..
Yes i'll watch with interest,so they do conversions in the states ?
Old 06-12-2013, 05:40 PM
There are a couple of places that are based in the US. But the problem is, from what I have read you can only use them if you are importing under the Personal Imports Scheme (i.e. it looks like you have to use an Australian based converter if you want to just buy an F350 in Oz).
The place I want to check out is: 4 Steer Conversions "right hand drive"
Looking at the videos they have:
Their work appears to be of high quality.
The other place that I have spoken to is:
US World Direct | USWD
(They have an office here - but the conversions happen in New Zealand) - they seem to have done more conversions, but they have a 7 month waiting list currently and you are looking at an additional 5k because you have to first ship the truck to NZ, then to Oz.
Old 06-13-2013, 09:05 PM
Nkelly's Avatar
Farkall User
Thanks mate,good info i'll have a look..
Old 06-14-2013, 03:53 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Quote:
All good bruva. Im leaning towards a RAM for my next ruck
Old 06-14-2013, 05:39 PM
Nkelly's Avatar
Farkall User
Quote:
How dare you,shame on you turning ya back on the ford bruvva hood..
But it will make our GTG more fun
Blah fords are **** heaps
Bull**** dodge's are dodgy man..
A chev f**k who would own a chev heapsa sh&t
It'll be good
Old 06-14-2013, 09:12 PM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Ha ha, can't wait to see one of the US style pull-offs, F250 vs ???
Old 06-19-2013, 11:04 PM
So reading through here, im not getting a good vibe about the 2010 F350. Might give it a pass. Next qstn, what are the main reasons you guys would not buy a chevy, wife wants to get a 1500 to pull her horse float but i know nothing of chevys etc etc. Thanks
Old 06-19-2013, 11:56 PM
They are good trucks, but can only get them as petrol... i.e. chew through petrol (or LPG), particularly when towing.
Old 06-20-2013, 12:37 AM
thanks mate, what about the 2500 LTZ model?
sold VROD Ford Truck Parts for Sale 2 02-18-2015 08:26 AM
2010 F450 DRW 6.4L Milpac General Diesel Discussion 6 06-02-2013 07:17 PM
lucas oil treatment tsgtbdl 1999 to 2016 Super Duty 3 07-13-2011 07:24 PM
best programer for 2010 6.4L power stroke? bulverde bill 6.4L Power Stroke Diesel 23 04-11-2011 01:26 PM
F150 Diesel IS Confirmed Trevor1 2009 - 2014 F150 109 12-05-2007 10:02 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
