Oil & Lubrication Tech Info Thread
<hr style="color:#D1D1E1; background-color:#D1D1E1" size="1">
Passenger Car Motor Oil (PCMO):
Virgin Oil Analysis (VOA) of some popular SN/GF-5 mineral oils https://www.ford-trucks.com/forums/9...ipe-chart.html
VOA of 24 Synthetic SN/GF-5 Motor Oils. http://pqiamerica.com/March2013PCMO/...sallfinal.html
Direct Injection Engine Lubrication & fueling. https://www.ford-trucks.com/forums/1...d-fueling.html
The Why For Boron In Our Lubricants. https://www.ford-trucks.com/forums/1...ubricants.html
Heavy Duty Motor Oil (HDEO):
HDEO Proposed Category 11 (PC-11) upgrade timeline. https://www.ford-trucks.com/forums/1...-timeline.html
Some HDEO VOA, including Motorcraft 15-40. https://www.ford-trucks.com/forums/1...r-oil-voa.html
Oil Life Monitors:
How Oil Life Monitors work. https://www.ford-trucks.com/forums/1...-monitors.html
Oil Filtration:
How our oil filter media works. https://www.ford-trucks.com/forums/1...icles-out.html
Motorcraft filter cutaway comparison https://www.ford-trucks.com/forums/1...ion-views.html
Oil filter differential pressure. https://www.ford-trucks.com/forums/1...-measured.html
Air Filtration :
Grease:
Rust Busters:
Oil Life Monitors:
Oil Filtration:
Air Filtration :
Grease:
Rust Busters:
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1><!-- / icon and title --><!-- message -->
Engine Oil Mini Tutorial. https://www.ford-trucks.com/forums/11...-tutorial.html
The Why For Boron In Our Lubricants. https://www.ford-trucks.com/forums/1133128-the-why-for-boron-in-lubricants.html
The Why for Moly In Our Lubricants. http://schaefferoil.de/sheets/praesentationen/factmoly_en.pdf
The Story On Viscosity. http://www.lelubricants.com/lit/news..._viscosity.pdf
Virgin Oil Analysis (VOA) of some popular SN/GF-5 mineral oils https://www.ford-trucks.com/forums/93...ipe-chart.html
Direct Injection Engine Lubrication & fueling. https://www.ford-trucks.com/forums/11...d-fueling.html
Heavy Duty Engine Oil (HDEO):
HDEO Proposed Category 11 (PC-11) upgrade timeline. https://www.ford-trucks.com/forums/11...-timeline.html
Some HDEO VOA, including Motorcraft 15W-40. https://www.ford-trucks.com/forums/12...r-oil-voa.html
Oil Life Monitors:
How Oil Life Monitors work. https://www.ford-trucks.com/forums/11...-monitors.html
Fords input on how its IOLM works. http://owner.ford.com/servlet/Conten...=1239636411265
Oil Filtration:
How to evaluate oil filter design. http://www.machinerylubrication.com/...te-oil-filters
How to convert filter Beta Ratio into % filtration. https://www.ford-trucks.com/forums/1011250-converting-filter-beta-ratio-to-filtration-efficiency.html
How our oil filter media works. https://www.ford-trucks.com/forums/12...icles-out.html
Motorcraft filter cutaway comparison https://www.ford-trucks.com/forums/12...ion-views.html
Oil filter differential pressure. https://www.ford-trucks.com/forums/12...-measured.html
Air Filtration :
Gotta have clean Air, to have clean oil. For reference, some air filters tested to ISO-5011. http://www.billswebspace.com/AirFilterTest.htm
Grease:
STLE rules of thumb in changing grease recipes. http://www.stle.org/resources/articl....aspx?did=1667
Compatibility chart choices, pick the one thats easiest for you to read. https://www.ford-trucks.com/forums/12...l#post13041354
Rust Busters:
A loosening torque test with some commercial products & a homebrew. http://bbs.homeshopmachinist.net/thr...enetrating-Oil
Owners Manual:
No cost owners manual download, 1996 to present, if you don't have one, or don't know what lubes or filters are specified for your Ford. http://www.fleet.ford.com/maintenance/owner-manuals/
Oil Life Monitors:
Oil Filtration:
Air Filtration :
Grease:
Rust Busters:
Owners Manual:
