Tech Info - Ford Truck Enthusiasts Forums
Tech Info
Old 06-09-2013, 07:30 PM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
Tech Info
Passenger Car Motor Oil (PCMO):
Engine Oil Definition: Motor oil - Wikipedia, the free encyclopedia
Engine Oil Mini Tutorial: http://www.ford-trucks.com/forums/11...-tutorial.html
Engine Oil Myth Busters: http://www.ford-trucks.com/forums/12...h-busters.html
The Why For Boron In Our Lubricants: http://www.ford-trucks.com/forums/1133128-the-why-for-boron-in-lubricants.html
The Why for Moly In Our Lubricants: http://schaefferoil.de/sheets/praesentationen/factmoly_en.pdf
Virgin Oil Analysis (VOA) of some popular 5W-30 SN/GF-5 mineral oils: http://www.ford-trucks.com/forums/93...ipe-chart.html
VOA of 24 Synthetic 5W-30 SN/GF-5 Motor Oils: March 2013 - Test Results for AP
VOA of a number of 5W-20 SN/GF-5 Motor Oils: http://www.pqiamerica.com/Feb2014/co...ed5w20ALL.html
Direct Injection Engine Lubrication & fueling: http://www.ford-trucks.com/forums/11...d-fueling.html
Heavy Duty Engine Oil (HDEO):
HDEO Proposed Category 11 (PC-11) upgrade timeline: http://www.ford-trucks.com/forums/11...-timeline.html
Some HDEO VOA, including Motorcraft 15W-40: http://www.ford-trucks.com/forums/12...r-oil-voa.html
HDDEO: EDIT: 1/1/16, Link became infected with malware Axpergle & has been removed. We don't know when the infection happened, so if you used that link, perform a security scan for Axpergle malware & remove it without delay. Will seek another good spider diagram to put up) Helpful site with a spider diagram with click on pull down menu's for spec overlay comparison, ect, info about PC11-A & PC-11-B engine lubricants
Oil Life Monitors:
How Oil Life Monitors work: http://www.ford-trucks.com/forums/11...-monitors.html
Fords input on how its IOLM works: EDIT Link 12/19/15 http://www.lombardfordwarrantys.com/...ence-Guide.pdf
Oil Filtration:
Oil Filter Types: Oil filter - Wikipedia, the free encyclopedia.
Motorcraft filter cutaway comparison: http://www.ford-trucks.com/forums/1225186-side-by-side-exploded-oil-filter-construction-views.html
How to evaluate oil filter design: How to Evaluate Oil Filters
How our oil filter media works: http://www.ford-trucks.com/forums/1232499-how-our-oil-filter-media-works-no-it-doesnt-strain-filter-the-particles-out.html
Convert filter Beta Ratio into % filtration: http://www.ford-trucks.com/forums/1011250-converting-filter-beta-ratio-to-filtration-efficiency.html
Oil Filter Differential Pressure: http://www.ford-trucks.com/forums/12...-measured.html
Bypass Filtration: Understanding Engine Oil Bypass Filtration
The Poor Mans Oil Analysis: Get Ready for More Soot In Engine Oil
Air Filtration:
Air Filter Types: Air filter-Wikipedia, the free encyclopedia.
Gotta have clean Air, to have clean oil. For reference, some air filters tested to ISO-5011: ISO 5011 Duramax Air Filter Test Report
Filter Manufacturers Counsel Air Filter Micron Ratings: https://aftermarketsuppliers.org/sit...ittee/04-3.pdf
Grease:
STLE rules of thumb in changing grease recipes: Document - A Review of Grease Compatibility
Compatibility chart choices, or scroll down to post 2, ect & pick the chart thats easiest for you to read & interpret: http://www.ford-trucks.com/forums/12...l#post13041354
Storing Grease: Storing Grease to Avoid Bleed and Separation-
Rust Busters:
A loosening torque test with some commercial products & a homebrew: Please confirm MW article on Penetrating Oil
Gasoline Tutorial: Likely more than you'd ever need to know about gasoline. http://www.faqs.org/faqs/autos/gasoline-faq/part1/
AAA Test Of Top Tier & LAC Gasoline Engine Deposits http://www.ford-trucks.com/forums/14...-deposits.html
Ethanol Free Gasoline:
For those with vintage rides, or who just don't want to burn ethanol in their engines: Ethanol-free gas stations in the U.S. and Canada
Owners Manual:
No cost owners manual download, 1996 to present, if you don't have one, or don't know what lubes or filters are specified for your Ford: Owner Manuals | fleet.ford.com
Diagnostic Trouble Code List Ford : P=Power train - B=Body - C=Chassis - U=Utility/System
https://edgeproducts.com/app/uploads...cle-pdf-41.pdf
Motorcraft USA Product Catalogue:
https://www.fcsdchemicalsandlubricants.com/main/
http://www.fordparts.com/?searchid=3...170213154229:s
Factors That Affect Oil Filtration pawpaw Oil & Lubrication 0 03-23-2016 12:05 AM
Oil & Lubrication Tech Info Thread IB Tim Oil & Lubrication 1 06-18-2013 07:10 PM
Wagon Wheels, Rings, Center Caps aeldk5g 1987 - 1996 F150 & Larger F-Series Trucks 0 05-31-2013 12:16 PM
MASTER COPY old Excursion Forum Tech Folder Stewart_H Excursion - King of SUVs 0 02-02-2012 12:49 AM
Converting Filter Beta Ratio To % Filtration Efficiency pawpaw Oil & Lubrication 0 11-17-2010 01:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
