Too much Vacuum advance? - Ford Truck Enthusiasts Forums
Old 06-09-2013, 06:16 PM
march's Avatar
march march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
Ok! With the help of some folks on this forum I was able to unfreeze my mechanical advance. The mechanism was frozen partly advanced, so I had to re time it. Now it's running like crap with the vac advance connected. The advance is way past the timing marks. It put an allen wrench in the vac to adjust, but it doesn't engage with anything. Seems to be happy without the vac advance. I don't drive it alot so I'm not too concerned about gas mileage. Is it worth messing with or should I just leave it disconnected?
460 duraspark II, D3V Heads
Old 06-09-2013, 11:17 PM
march's Avatar
After more playing around, It runs rough when not under load (just cruzin at 40 or reving the engine in the driveway). It's like it gets too much vac advance when not under load. I don't get the same problem when I disconnect the vac advance.
How to Set 352 Timing w/Vac Advance 64F-100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 13 09-29-2016 09:04 AM
PCV causing major vacuum loss. ebbsrig 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 10-27-2014 10:32 AM
vac can abyars111 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 10-02-2014 11:02 PM
351w ignition help alex2824 Performance & General Engine Building 5 05-25-2014 11:38 PM
Too much Vacuum advance? march 1973 - 1979 F-100 & Larger F-Series Trucks 15 06-22-2013 10:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
