Need some 53-56 fender measurements Are 500's and 350's the same?
Old 06-09-2013, 02:00 PM
Olweldinrig's Avatar
Olweldinrig
Olweldinrig is offline
Are 1/2 ton,1 ton and larger trucks all different size wheel opening?The 100's are for sure small I realize.Can you guys give me some measurements for openings in 1 ton and 1/2 ton.I am trying to figure out which fenders I have to use and whether or not I can center my cab and fenders using the 500 fenders I have if I end up using 1 ton fenders or are they the same as the 500's?.So are the center to front and back of fender the same within the all wheel wells opening?
Thanks in advance
Old 07-01-2013, 09:55 PM
ford1954250's Avatar
ford1954250
ford1954250 is offline
53-56 fender opening withs
hello there i can measure mine and tell u what mine are i have a 1954 f-250 and i been buying parts for it some off bigger trucks and i know a 54 f-100 fenders are differnt just in the wheel well opening then my 54 f-250 the f-100 is like few inches smaller then the opening on my 54 f-250 and i know a f-350 in a 53-55 is the same fender as my 54 f-250 but is off on a f-100 and i know on a say 53-55 f-500 and a 600 the fenders are more bigger then my 54 f-250 fenders but i have baught doors off of a 1954 2 ton and they work perfectlly on my 54 f-250 . so some things are the same and some things aint like from the fenders on them down to the frames and wheel base and etc all that is differnt from one to the next f-100 to say f-600s longer wider etc .
Old 07-02-2013, 11:04 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,449 Likes on 1,396 Posts
I don't have any measurements but I can tell you according to the Ford chassis parts catalog, the opening size has more to do with oem tire size than series. F-100-350 with 16" tires had one fender, F-250-600 with 17" or 20" tires has a different fender. So the answer to your original question of does F350's use the same fender as F-500's, the answer is, 'it depends'...
Old 07-02-2013, 01:58 PM
Harrier's Avatar
Harrier
Harrier is offline
Well now that's interesting. I always thought the F250 through F600 all had the same fenders. Nothing is ever simple is it...
Old 07-07-2013, 01:47 AM
Olweldinrig
Thanks guys,I was told also the size was an option possibly?I also had a chance to lay half tons on top of a big one and looks to be centered the same.
tinman52
10-25-2017 10:14 AM
Psmith1951
03-10-2014 08:39 AM
corinil
10-08-2012 06:49 PM
takid455
11-03-2009 11:02 PM
docholiday72tx
08-24-2005 09:34 PM
Quick Reply: Need some 53-56 fender measurements Are 500's and 350's the same?
