Did I screw up?
Did I screw up?
Hopefully not.
Today I had some garage time, decided to change oil and filter in the 223. After I was all done and cleaned up, I noticed that the 30w oil I put in the truck said it was for Diesel engines. I did not notice this when I was putting it in. The truck is running good, oil pressure was reading the usual 50-60 on the aux oil gauge I put in last year. So should I just leave it or drain it all and change the filter again. Thoughts, suggestions, prayers appreciated.
In the past, there was an advantage to using diesel oils in OHV engines to get the ZDDP. Not so any more. Diesel oil won't hurt a flathead, but plain old new-spec oil is better for it.
Here's an interesting article on diesel oil (only): http://www.turbodieselregister.com/TDR57_Oil.pdf
This is an excellent article on modern oils (non-diesels): http://www.nonlintec.com/sprite/oil_myths.pdf
JSolve
1999 to 2016 Super Duty
12-24-2020 01:28 PM
