Gas spilling out! Help!!
I went out to my truck and found the gas coming out of the fill spou, like it was being forced out. It has eaten away my paint and screwed it up pretty good. There seems to be a lot of pressure in there. The fuel filter is remaining full, but it used to drain back out when parked. I need to know why there is so much pressure. The truck is a 62 with a 223 engine and everything is pretty much stock. Help!!!!
Full tank at night, when it gets hot it expands and spews, it will take you a time or 2 to remember that, then I only fill up before I do run around and go home so I use a few gallons, and even then, I still park with the filler necks UPHILL. My 63, my 66, and my 77 ALL do it with a full tank/tanks. Mainly only in summer, but have had it happen in winter when cold in a.m. and I filled up right before I got to work, warmed up and she starts spewing. Then you get to drive home smellin like a molotov cocktail,,,
Get a new fuel cap.. it should allow for vacuum ventilation but not purge ventilation unless you over filled it... Fuel tanks should not be filled more than 82-87% due to expansion... If you fill early in the morning fill it only 75% Cool summer mornings with hot summer afternoons are the toughest time...
I had just bought a new locking gas cap from so-cal speed shop that was supposed to be made for my truck and I filled the truck up last night around 3 or 4 so it was already pretty hot. Maybe it was completely full, but I had driven a good 10 miles before it was parked and did this. I think that the design of the street leaned in to the fill side and that made things worse. I'm hoping that filling less will help but now I'm going to have to fix the paint. Tough lesson.
This is something that occurred in behind the seat tanks. I first saw it in the 1950s with my dads truck.
You can use a couple choices don't fill it up or spend a lot of money on caps that don't work.
John
Heat causes gasoline to expand, so when you fill the tank all the way up (18 gallons as original), some will leak out. A very common problem on these trucks.
