rust - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
rust
Old 06-09-2013, 11:20 AM
shawnhunts's Avatar
shawnhunts shawnhunts is offline
shawnhunts is starting off with a positive reputation.
rust
I have a question for you all. How do you keep your truck from rusting? OUr f-250 shows no signs of rust yet and we want to keep it that way. Yes, I got her for sale but I dont find anything out there to replace her with yet so how do we keep her in ship shape? thanks in advance for your info.
shawn
Old 06-10-2013, 09:59 AM
Chad149's Avatar
Chad149 Chad149 is offline
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
I try to spray some Fluid Film into the trouble area's once a year or so. John Deere stores carry it or can order it for you.
Old 06-10-2013, 10:08 AM
FordBlueHeart's Avatar
FordBlueHeart FordBlueHeart is online now
FordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud ofFordBlueHeart has much to be proud of
Same here. I used a whole gallon last fall. I do have surface rust on the frame now, but my truck is an 06
Old 06-10-2013, 10:16 AM
bbender85's Avatar
bbender85 bbender85 is offline
bbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud ofbbender85 has much to be proud of
sounds like it's alot of work but if you can pull the box sides off there are foam pieces over the wheel wells that hold moisture; some guys remove them. really they're the source of the typical rust on these trucks.
buddy of mine coats his wheels wells and frame with some type of petrolium-based every wall.. probably like the fluid film chad mentioned.
Old 06-10-2013, 11:01 AM
shawnhunts's Avatar
rust
Thanks guys, my brother mentioned a place that does rust proofing in midland called henderson bros. Anyone heard of it?
Old 06-10-2013, 03:22 PM
Toyman's Avatar
Toyman Toyman is offline
Michigan Chapter Ldr
Toyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputationToyman has a superb reputation
Fluid film is good stuff. Works great.
You can also get a POR type paint and paint the underside of the truck. I have done this on my last 2 Jeeps, not only does it look good, it really stops the rust from growing and seals out the moisture so what is there won't get any worse.
Old 06-10-2013, 10:27 PM
Fordman96 Fordman96 is offline
Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.
Home Depot sells this Naval jelly. You clean up the rust spot really well (just get rid of the loose stuff with like sand paper or a wire brush), then just rub it on with a paint brush, let it sit for 10-15 minutes and spray it off with a hose. Have been using it for a few weeks as I've been working on the Wronco and it seems to work like a charm in most spots that don't have rust caked in.
Multiple questions about my '72 F100 Truck Ravenjinn82 1967 - 1972 F-100 & Larger F-Series Trucks 11 09-11-2015 03:08 PM
end of winter rust success stories - got any? speakerfritz 1999 to 2016 Super Duty 28 04-22-2015 10:46 AM
I just can't keep her going! lumberjack_964 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 08-15-2013 05:29 PM
help me and my wife please ranger1999 Bob General NON-Automotive Conversation 18 12-18-2009 10:18 AM
A1fendermender-WHERE ARE YOU?!? barryo Paint & Bodywork 7 02-23-2001 09:04 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
