'03-'04 Mirror Swap Question - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-08-2013, 11:44 PM
lamar804's Avatar
lamar804 lamar804 is offline
lamar804 is starting off with a positive reputation.
Arrow '03-'04 Mirror Swap Question
Hey guys,
I've been searching for the "how to" info on the '97-'02 to '03-'04 signal mirror swap for 3 days! (it disappeared with the other site FTW) About 7 years ago I completed this swap on my '97 XLT, but now my '97 is long gone and I just recently picked up an 2000 XLT and bought a set of '04 signal mirrors, I can not remember how I did it!
Has anyone recently done this? Or does anyone know the wiring color codes for right, left, up, down, puddle light, heat, signals on the '03-'04 mirrors? Also, the colors for the '00 switch. Once I get that info, I do remember wiring the mirror signals directly to the corner lights.
Any help would be greatly appreciated
Old 06-09-2013, 12:05 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
I've attached the mirror wiring diagrams for 2000 and 2003, have a ball.
You didn't say that you had memory mirrors, so I posted the diagrams without memory.
Old 06-09-2013, 12:31 AM
To help you with the turn signal wiring I've attached the diagram you need. If you locate connector C206 as shown, both the left and right turn signal wires pass through it. This is a good place to tap into those circuits if they do not already run into the doors.
Old 06-09-2013, 12:42 AM
lamar804's Avatar
Wow! That was fast! Thank you
Old 06-23-2013, 05:35 PM
lamar804's Avatar
***Update***
Quote:
Thanks again for your help Alloro.
Here's a update for others wanting to swap their mirrors. On my 2000 xlt, I found it was already wired for the signals and heat even though my original mirrors were not equipped with heat or signals.
<br>
This is for the left side, but the right is the same.
<br>
light green/white stripe= Left Turn Signal/ Connect to LG/W-stripe on '04 mirror harness
<br>
Dark green/purple stripe= Heated Mirror Feed/ Connect to Dark green/purple stripe on '04 mirror harness
<br>
Black/pink stripe on the '04 mirror harness is for the Puddle light, I wired it to the Black/blue stripe wire going to the light at the bottom of the door.
<br>
I'm still trying to figure out the wires for movement. I only have 3 wires left on my original harness (Red=Left/Right Motor, Dark Blue=Up/Down Motor, and Yellow=Left Remote Mirror Solenoid Control) and 8 wires on the '04 mirror harness (Red,Blue,Yellow/Red,Blue/Yellow,Gray,Gray/Red,Brown/White, and Red/White)
<br>
So, right now they're mounted with working signals, heat, and puddle lights. I'll to work out the wires for movement next weekend.
Old 06-23-2013, 06:07 PM
Quote:
I don't understand, everything is right there on the two wiring diagrams. Maybe you need the 2003 diagrams for the mirrors with memory control. I've attached the left and right diagrams, see if they make a difference.
Old 06-23-2013, 06:19 PM
lamar804's Avatar
Lol, Alloro I'm terrible with wiring diagrams. Although they were very helpful getting me as far as I got today. I just need to study them a bit more to figure out how the 8 wires are suppose to match up with the 3 I have left on my original harness.
Old 06-23-2013, 06:21 PM
Did you see the two new attachments to my last message? I edited the message and added them after, so I don't know if you responded before I posted them.
Old 06-23-2013, 06:23 PM
I don't think you need to connect to the wires for the 2 variable resistors, those tell the memory module the position of the mirrors. You should just need the 4 motor wires, with one from each motor going together on the yellow (common) wire.
Terminals 5 & 3 for the left mirror and terminals 5 & 4 for the right mirror appear to be the common wires that get spliced together.
Old 06-23-2013, 06:35 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
i've been thinking of doing this for awhile now, great to have the wiring diagrams.
Old 06-23-2013, 07:05 PM
lamar804's Avatar
Thank you for those! Now I understand.
Old 03-07-2014, 11:29 PM
liftnw8z's Avatar
liftnw8z liftnw8z is online now
(CL) Team Brahma
liftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputationliftnw8z has a superb reputation
Quote:
I'm now giving thought to this swap myself on my 98. Looking around for mirrors in the junkyard to do the swap. I have signal and power - no heat or fold or anything like that.
Old 03-09-2014, 01:44 AM
5.4T's Avatar
5.4T 5.4T is offline
5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.5.4T has a very good reputation on FTE.
Lamar can you post pics of the finish product ?
Old 03-09-2014, 11:33 PM
lamar804's Avatar
Quote:
Hey, here's the pic of them installed. I'll post a better one after work tomorrow.
installed 2008 mirrors on my 2001 today (pics) TNT in Round Rock 1999 to 2016 Super Duty 161 01-29-2017 05:21 PM
SWAP: Tow Mirrors to Signal Tow Mirrors A/Ox4 1999 to 2016 Super Duty 4 05-15-2011 09:38 PM
08' and up tow mirrors on my 05' excursion? LRSTony Excursion - King of SUVs 2 11-03-2010 09:20 PM
03 EB side mirror security approach lamp bulb replacement Ammie 1997-2006 Expedition & Navigator 6 04-04-2010 11:59 AM
What is the difference in years for HPOP? BigRy 6.0L Power Stroke Diesel 2 11-18-2009 12:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
