Coolant puking need help! 6.0
Im fairly familiar with what puking coolant means... head gaskets. I thought thats what it was. I took it to a Ford Dealer and an independent shop and they each ran 3 separate head gasket tests and the truck passed all of them perfectly. No blown head gaskets.
Having said that, I have no clue why coolant continues to puke out of the degas bottle little bits at a time - never a lot at once. Any ideas what this could be?
The dealership and indy shop couldn't help you answer this question either?
Perhaps the cap is bad, they are known to have issues and I've already replaced mine.
Are you overfilling it? There is a TSB out that redefines the min and max lines on the degas bottle. It's applied on a sticker outside the degas bottle for reference.
It only seems to happen when driven for long distances - 20+ miles. The tempurature around my area has been 80+ for the last month or so. I do not have any gauges (planning on buying them this summer), and I have not done anything to the cooling system other than new coolant.
I've heard a clogged EGR valve could also be responsible and I will be taking mine off and cleaning it tomorrow.
Coolant is at the "low" mark when its cold. After driving in 90* temps for 30 mins with some stop-and-go traffic, the coolant has expanded to almost all the way to the top. Not leaking out just yet but it is fairly close.
What tests did the indy shop do to "confirm it wasn't head gaskets"?
The EGR valve isn't the other main culprit in coolant puking (besides head gaskets), it is the EGR cooler.
It is possible to overheat from water pump failures, etc. We need to know the coolant and oil temps when the engine is fully warmed up. I would also advise installing a pressure gauge on the degas bottle.
on
https://www.ford-trucks.com/forums/1...9-08-03-a.html
everyone always claims headgaskets it just not so
All that costs money which I do not have at the moment. How much is it to have gauges purchased and installed?
Taking off the EGR valve will tell me if the EGR cooler is going bad. Thats the other reason I wanted to take it off. If the valve is too clean (looks almost like it has been steam-cleaned) or if the valve is damp then that means the EGR cooler is shot. Im really hoping thats not the case. Ill have a pit in my stomach tomorrow right as Im about to take the valve off.
They ran pressure tests same as the dealer did - No loss of compression was found by either.
on
steamed cleaned on the other hand is a cooler.
why not just follow the tsb 09-08-03 and not guess what it is. its pretty simple and will get you the diag you need
