1994 ford f350 351 engine .
should be on a bracket mounted to the firewall or just below the edge of the firewall toward the pass. side above the right bank valve cover. typically mounting is right on or at the HVAC assembly. if all else fails trace the vac line coming out of the upper plenum to where it plugs into a box with 3 wires coming out of it!
levigranger
04-12-2011 08:01 AM
