Installing autometer fuel gauge - Ford Truck Enthusiasts Forums
Old 06-08-2013, 11:12 PM
BigRobK's Avatar
BigRobK BigRobK is offline
BigRobK is starting off with a positive reputation.
Hello all, what is the ohms specs for my 68 f100 with stock tank sending unit. Auto meter was 3 to choose from,
1: 0 ohms empty 90 ohms full
2: 72empty 10 full
3: 240 empty 30 full
Old 06-09-2013, 12:29 AM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Stock sender? Please read Fuel Tank Sending Unit Tech - FORDification.com
... got to the bottom of the page because there appears to be issues between OEM and aftermarket senders.
Old 06-09-2013, 09:59 AM
LittleG LittleG is offline
LittleG is starting off with a positive reputation.
If you have a stock sending unit, 70-10 is the one you want. I just installed one in my truck last week. It's working at this time but not very accurate. There seems to be a lot of movement on the needle. I did not connect the voltage regulator initially but I think I will go back and try it to see if makes any difference. The stock gauge was working ok so I think the sending unit is ok. I would be curious if you see the same behavior after installing yours.
Old 06-09-2013, 10:03 AM
HIO Silver's Avatar
Quote:
Read the article I posted and ya might understand why it isn't accurate.
Old 06-10-2013, 11:08 PM
BigRobK's Avatar
Thank you great article! I'm ordering the 240 Ohm Empty / 33 Ohm full gauge and sending unit.
Old 06-11-2013, 12:26 AM
HIO Silver's Avatar
You're welcome. Glad to help.
Help finding sending unit/gas gauge that are compatible. ford5.8 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-19-2016 07:18 PM
Aftermaket Sending unit bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-26-2016 01:43 PM
Fuel Gauge Reads Empty - Senders OK ? Birken Vogt 1987 - 1996 F150 & Larger F-Series Trucks 5 09-18-2016 08:35 PM
fuel gauge ohms southtexasidi 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 08-06-2013 07:02 PM
Fuel sender ohms? fordtruggy 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2013 11:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
