brakes still not working well
Just finished the radiator flush and want to take the truck out for a spin but now that it is "drivable" I thought I would check to see if the brake work I did last week was any good. I did new Master and front wheel cylinders, all new brake lines(hard and soft on the whole truck), front shoes relined and front drums turned, and whole system filled with fresh dot 4 and bled. Now the pedal is hard as a rock and the truck barely stops. What have I missed?
Thanks for any help,
Fixnair, I say I have the stock master. What I have is what the online and local places list add the stock matter and it is the same as what was in it when I got the truck. It is a 1.25" master which is huge. Perhaps if I switch to 1.125" I will get better Pedal feel. I'll have to see if there is such a cylinder with the right bolt pattern
what happens when you STOMP on the brakes ?? not being power assist ..meen's you need a lot of force to haul it down..I am reminded every time I climb outa my 54 ans in the wife's chev ..will anything lock up ? have you bedded the shoes in ?it does take a while to get everything worked in together ..,,
shortblock2000
04-08-2005 12:14 PM
frd56f100
07-23-2001 08:44 AM
