Fuel Octane - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Fuel Octane
Old 06-08-2013, 03:38 PM
judithgap's Avatar
judithgap judithgap is offline
judithgap is starting off with a positive reputation.
Fuel Octane
Can you use the higher octane (above 87) fuel in the 6.2 and would it increase the performance?
Old 06-08-2013, 09:52 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
You can use higher octane fuel in the 6.2L or any engine. I doubt you'll see much difference if any in performance, especially without an aftermarket programmer.
Old 06-09-2013, 12:13 AM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
Quote:
^^^^ yep, save your money
Old 06-09-2013, 08:37 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold2000silverbullet is a splendid one to behold
Expect a 10-15hp increase on 91 or greater octane (without a tuner). Whether you can "feel" this or not could be up for debate, but you will see an increase in HP. This is in the "ask the engineer" thread for reference.
Old 06-09-2013, 08:42 AM
6.2gasser's Avatar
6.2gasser 6.2gasser is offline
6.2gasser is starting off with a positive reputation.
You can even put E85 flex fuel in it. I don't recommend it though, I did one fill up and the mileage dropped off 3-4 mpg!! Though it's less expensive than gas you will be filling up more frequent. If I was really concerned with our air quality and saving the earth I would have bought a Prius.
Old 06-09-2013, 08:48 AM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
Quote:
I know it's going to hurt the mileage but I just have to give it a try someday after I get a few more miles on the clock.
Denny
Old 06-09-2013, 08:55 AM
6.2gasser's Avatar
Quote:
Denny
Try it out, I did not feel any difference in performance. The overall cost is pretty much a wash compared to gas with the lower price/lower mpg's of E85. No need to constantly be at the pump IMO.
Old 06-10-2013, 12:43 PM
2011F250Lariat 2011F250Lariat is offline
2011F250Lariat is starting off with a positive reputation.
Quote:
Yep, I read the same in the engineer thread, and I agree with silverbullet, since the 6.2L is a flex fuel engine the computer can certainly make some adjustments to accommodate higher fuel octane, otherwise you would not be able to put either fuel in without making any changes. I do notice quite a performance improvement on E85 though, which is supposed to be over 100 octane, something like 105, and some even higher, but its not much less expensive then gas yet way worse on gas mileage.
Old 06-14-2013, 07:38 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
We are 2300 miles into our vacation and are now in Tennessee and I went from running 87 when we left Canada to running 93 octane down here and I will say that you can feel the difference in power hauling our 8500 lb 34 ft travel trailer. I have been running in manual mode and have very rarely had to go below 4th gear to maintain 60mph and the lowest was 3rd. We are in Pigeon Forge for a few days and it pulled all the hills at 60+ around here. So I say it sure does make a difference and the engine even feels better.
Old 06-14-2013, 01:55 PM
sledjunk's Avatar
sledjunk sledjunk is offline
sledjunk is starting off with a positive reputation.
Quote:
How does it affect your mileage? I realize that it might be hard to tell when towing over varying terrain, but just curious.
Old 06-14-2013, 07:03 PM
I have always towed with 93 octane fuel. It's an old habit from the days of my old 95 5.8L. If I tried to tow with 87 or even 89 octane it sounded like a thousand little men beating on anvils with little hammers in the engine any time I hit even a slight grade. I've seen what detonation can do and what a platinum plug electrode does to a cylinder from detonation. I can say that when towing it makes a difference. I don't notice much difference running 93 octane over 87 octane while dead heading.
To use octane booster or not 89f350xlt 1987 - 1996 F150 & Larger F-Series Trucks 5 11-07-2015 06:43 PM
higher octane fuel for a regular engine? jeepnix 1997 - 2003 F150 11 06-30-2012 10:15 AM
Octane adjustment Rod???? ymeski56 1987 - 1996 F150 & Larger F-Series Trucks 41 08-13-2011 04:55 PM
Is the higher cost of 93 octane fuel worth the mpg increase? Johnlwlr Modular V10 (6.8l) 18 04-06-2011 03:10 PM
What type of fuel for a V10? OutlawNomad Excursion - King of SUVs 10 02-24-2010 11:22 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
