Thinkin about a Turbo-setup
I have a 1978 F100 with a 351-w and c-4.
I've been thinkin bout putting a turbo setup on it somewhere down the road... I have the oppurtunity to buy a used Garret T25 Turbo with a wastegate and intercooler (no blow off valve) for $250 (seems a bit high to me)
What I want to know, is this a good turbo for my motor, how would I go about plumbin it in, and how much would be a good price for the turbo?
I've been researching turbos for a 300 project. From what I've learned, that turbo would be way too small for your application. This site will help you in narrowing down what you need:
Squirrel Performance
There are a ton of variables in picking the correct turbo, though. Such questions as are you after low-end torque for towing, or are you building something to run at a drag track? Will it be a daily-driver type vehicle or only used on the track?
For starters, I would suggest getting the book Turbo: Real World High-Performance Turbocharging Systems by Jay. K. Miller. ISBN 078-1-932494-29-7
Here's a good website to dig through: TheTurboForums - Index
Digging this up from a while ago, figured I'd see how your reading has gone on this subject.
The turbo I'd suggest for a stock ish 351 is a 94-98 (even a 99-03) powerstroke turbo.
The older one is a t4 flange where the superduty turbos are a round vband flange. (I make a t4 flange adaptor for my projects)
Plumbing it is easy in the old trucks. Find a set of shorty mustang headers and flip them around and put turbo on pass side (move battery to drivers because ps pump is over there and I don't want exhaust near it) and then route downpipe along valve cover and down.
I'd reccomend efi now. Use mustang 351 intake and find a harness from a foxbody (painless makes a sweet a9l ecu harness) to graft in or any other ford mass air car with tuning support.
injectors and fuel pumps depends on your power level, same as the MAF (if you go that route)
have you considered a stand alone like a "fast"?
A mustang computer is very tuneable. They burn chips and have a number of user programming products.
Fuel pump will be a walbro hp255 or you can get a Bosch 044 pump that's about 310lph.
Walbro now makes a hp400 pump as well, but a single 255 will support 450whp.
Injectors are sized by hp. You can do formulas and stuff, but I'd suggest 30s or 42s. That will get you 400-550 hp safely.
You can use two "super 60s" which is the ford turbocoupe turbo or the t3/t4 eBay turbo, which is usually the same thing. Or if you have 600hp goal then use two holsets or a pair of decent turbonetics turbos.
I'd go single turbo and use either a 94-97 powerstroke turbo, or an ebay gt45 or t70. If you don't want eBay stuff then turbonetics make some good stuff.
I realize that you can't just toss on a turbo from a vw or a semi truck...
I suggested those turbos because I've used them all, on 2liters all the way to a 393 stroker motor.
As far as the fuel pump requirement... No such thing as too much. When you're putting boost to anything, start with a 255. The cost is the same as the smaller ones, and its the same physical size. I run 3 190lph pumps in my turbo mustang (just because I bought 40 of them brand new takeouts) but I run 2 hp255s in the 540whp 2liter talon.
My turbo 2.3 ranger that only makes 200whp uses a walbro hp255.
The miata with a 14b uses a walbro 255.
Turbos need to be sized not only to displacement, but head flow and useage of the vehicle.
I'd put a bigger turbo (proportionally) on a 5liter mustang then an automatic 351 truck. Different power/rpm requirements for each.
Let us know your engine combo and your hp goal, and what you want to do with truck.
trevorrules
06-21-2015 04:16 PM
