Using Ford 460 EFI system on an Edelbrock Victor EFI intake 50665 - Ford Truck Enthusiasts Forums
Old 06-08-2013, 01:12 AM
Iversen-fords's Avatar
Iversen-fords Iversen-fords is offline
Iversen-fords is starting off with a positive reputation.
I found this intake 50665 Edelbrock Victor Series EFI Intake for a 460. I've searched to see if someone has tried to adapt this to an factory EFI setup and no one has looked into to much. What are the chances of using good flowing carb heads, then using this intake and some how adapting the Ford EFI system and the upper intake to it? I think the difficult task will be getting the upper part of the intake to work on the intake and making sure has enough clearance to clear the hood and also plumbing the fuel system again. In doing all of this, your going to probably be converting to a MAF system also.
So.... has anyone thought of this setup or looked into? It's something I've been wondering about and I finally got the urge the ask.
1981 Bronco 302 Variable Venturi to EFI swap DesertBroncoFan 1978 - 1996 Big Bronco 1 05-19-2015 04:58 PM
?? about thermactor setup during rebuild (Piston, Cam, Intake swap) lazzarruss 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-27-2014 06:00 AM
460 efi to carb swap xavier23 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 01-08-2013 03:29 PM
Edelbrock 500 too rich-2bbl? Holley 390? EFI? newrider3 Ford Inline Six, 200, 250, 4.9L / 300 16 06-06-2012 01:18 AM
429/460 Intake Question Deerbowhunter Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 03-04-2006 09:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
