1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Firestone airbags not leveling F350
Old 06-07-2013, 06:25 PM
acf6's Avatar
acf6
acf6 is offline
Installed a set of firestone air bags on a 2013 F350 dually this morning. Owner was pissed when he first hooked up his trailer, an easy 4" of sag when it was on. For comparison, his 2004 F350 dually sags maybe .5-1" with the same trailer, not sure what it weighs
We aired up the bags after i was done, to 85 psi and the truck still sits about 1.5"-2" lower in the back. Do these things really sag that bad? Anything else we can do to level the truck out with a load?
Old 06-07-2013, 06:28 PM
senix's Avatar
senix
senix is offline
Received 1,415 Likes on 1,010 Posts
I'd consider something like a add a spring in the rear. 1" ought to do it.
Old 06-07-2013, 06:29 PM
acf6's Avatar
acf6
acf6 is offline
Yeah thats what i suggested as well. At least the overloads arent touching anymore! around 2-3" of clearance from those and the stoppers now
Old 06-07-2013, 06:31 PM
senix's Avatar
senix
senix is offline
Seems to be a theme since 2008 where the spring rates were soften for the unloaded ride.
I think they went too far for the 2011 and ups.
Old 06-07-2013, 06:38 PM
dualwheels66's Avatar
dualwheels66
dualwheels66 is offline
I am considering a 4" block instead of the factory 2" block, worst part is I should have done it BEFORE putting on the bags.
Old 06-07-2013, 06:49 PM
sbryan's Avatar
sbryan
sbryan is offline
Interesting to hear this because my new 2013 F350 SRW CC doesn't squat at all with the 16K toyhauler on the fiver. I do have the snow plow prep in front so the truck is level to start with but with the fiver on I'm barely touching the helper spring - might be down .5 to .75 from unloaded, no more.
Old 06-07-2013, 06:52 PM
acf6's Avatar
acf6
acf6 is offline
Wow, and this is a dually truck. Heres the exact same trailer on his 04...dont have a pic of '13 but the nose was sky high before, not terrible now but wish it was better. Should tell him to put the plow on the front, thatll level it
Old 06-07-2013, 07:17 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
these new trucks are just big soccer mom trucks, this past weekend my cousin wanted to sod his yard at his new house. Said ill lend the F350 for the work, two pallets of FRESH sod in the bed and three pallets on my 16ft 8k landscape trailer and i was still riding REAR HIGH. Yet a brand new F250 diesel next to me only had one pallet and was sitting like the rear springs were busted! The guy was like "i should have ordered a F350 instead" i laughed to myself and just said "yea thats why i did" but we all all know that isnt the real reason
Old 06-07-2013, 07:18 PM
SuperDutyScaler
by the way your truck looks SICK
Old 06-07-2013, 07:27 PM
sbryan's Avatar
sbryan
sbryan is offline
Just found this so so quality cell phone picture of the truck with the fiver attached. Not perfect because things are on level ground but I think you can see that there is almost no sag with the RV on the truck. No modifications to the suspension. 20" wheels with the Michelins. I think you can see from the wheel wells that the truck is level with the trailer on. On flat ground it is level - we measured sag at the RV dealer and it wasn't enough to write home about.
Old 06-07-2013, 07:31 PM
SuperDutyScaler
not trying to start a fight but i can clearly see the rear fender gap is a good inch to a inch and a half less than the front
Old 06-07-2013, 07:36 PM
sbryan's Avatar
sbryan
sbryan is offline
No offense taken. On level ground we measured between .5 and .75 sag. Not none but not enough to put us on the helper spring. In this photo the trailer is sloping uphill, the truck is sloping downhill. Like I said, not a great picture because the ground isn't level.
Old 06-07-2013, 07:38 PM
Tom's Avatar
Tom
Tom is offline
The Firestone kit provides 5,000 lbs of lift support at 100 PSI. Meaning that if the suspension wasn't at the original height with 100 PSI then he had over 5,000 lbs on the rear axle.
Hotpocket's Avatar
Hotpocket
Hotpocket is offline
indeed..looks like it sat down about 3-3.5 inches from stock height
Old 06-07-2013, 07:39 PM
F350-6's Avatar
F350-6
F350-6 is offline
Maybe, but it doesn't look anything like the new trucks I've seen hauling smaller trailers that make it look like the front wheels are about to come off the ground.
That's pretty impressive for no airbags I think. Maybe he has the trailer filled with helium or something.
Quick Reply: Firestone airbags not leveling F350
