1948 Radiator and cap 6 cyl 226
Old 06-07-2013, 07:57 AM
fordf348's Avatar
fordf348
fordf348 is offline
I am having some problems with my cooling system:
I am considering installing a 7# cap in lieu of the 4# cap.....I cant find one anyone know a model # ?
Also considering a new Radiator anyone have a good source?
Thanks
Ed
Near Philadelphia
Old 06-07-2013, 09:11 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
What are your cooling problems and why do you think a 7# cap would solve them?
Old 06-07-2013, 10:20 AM
fordf348's Avatar
fordf348
fordf348 is offline
Scott, after a ride of 100/200 miles I find that I have to add 4 to 5 quarts of coolant, I don't see any leakage other than at the overflow so I am thinking that what a local radiator man told me may work. That is before installing a new radiator to try the 7# cap and see if that helps
Thanks
Ed
Old 06-07-2013, 12:25 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is online now
http://www.summitracing.com/parts/snn-10228/overview/
Not the supplier of choice - this should be what you are after.
I'm a bit leery of a cap as the fix - curious to know how this turns out.
Old 06-07-2013, 06:25 PM
fordf348's Avatar
fordf348
fordf348 is offline
Thank you for the Stant part number......I will get one and let you know how it works out
Old 06-07-2013, 06:39 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
I wonder how this will come out, too. Sixty plus year old cooling system designed for 4 psi pressure now going to 7 psi. Perhaps the radiator guy sees a sale in his future.
Old 06-07-2013, 06:45 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
That is a lot of coolant to lose without a trace. Maybe install a catch can on the overflow tube and see what you get? Otherwise it could be internal......is it missing or fouling any plugs? Oil look OK?
Old 06-07-2013, 06:54 PM
Kurt G.'s Avatar
Kurt G.
Kurt G. is offline
I have heard of people installing too hi a pressure cap and doing damage to cooling system. I don't know if 3# increase would do it, did it work ok last year or before? Is tailpipe dry?
Old 06-07-2013, 07:43 PM
Kazoo's Avatar
Kazoo
Kazoo is offline
Is the existing cap new or old? Maybe 4 lb cap is just shot and not holding 4 lbs
Old 06-08-2013, 04:43 AM
fordf348's Avatar
fordf348
fordf348 is offline
The cap is new and the way it seats on the radiator looks good. I had figured on just going ahead and replacing the radiator but the radiator guy suggested trying the higher pressure on the cap, so if the radiator goes that is what is needed. Oil looks good, tailpipe is dry. Trying a catch can sounds like a good idea to try, it may prove where the coolant is going
Old 06-08-2013, 08:00 AM
needhelp49's Avatar
needhelp49
needhelp49 is offline
i thought this would be a good idea untill i did it and both water pumps blew the seals or whatever they use
Old 06-08-2013, 07:06 PM
fordf348's Avatar
fordf348
fordf348 is offline
Mr Need, what problems were you having when you went to the 7#cap instead of the 4?
Ed
Old 06-09-2013, 07:11 AM
needhelp49's Avatar
needhelp49
my water pumps leaked around the shaft i don't think they are designed for allot of pressure ether.
hotrodjohn71
04-25-2016 11:22 AM
Vegas123
08-27-2015 07:49 PM
Fastback460
1999 to 2016 Super Duty
15
02-25-2015 10:42 AM
tombogue09
05-03-2014 01:35 PM
Quick Reply: 1948 Radiator and cap 6 cyl 226
