1948 Radiator and cap 6 cyl 226 - Ford Truck Enthusiasts Forums
Old 06-07-2013, 07:57 AM
fordf348's Avatar
fordf348 fordf348 is offline
fordf348 is starting off with a positive reputation.
I am having some problems with my cooling system:
I am considering installing a 7# cap in lieu of the 4# cap.....I cant find one anyone know a model # ?
Also considering a new Radiator anyone have a good source?
Thanks
Ed
Near Philadelphia
Old 06-07-2013, 09:11 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
What are your cooling problems and why do you think a 7# cap would solve them?
Old 06-07-2013, 10:20 AM
fordf348's Avatar
Scott, after a ride of 100/200 miles I find that I have to add 4 to 5 quarts of coolant, I don't see any leakage other than at the overflow so I am thinking that what a local radiator man told me may work. That is before installing a new radiator to try the 7# cap and see if that helps
Thanks
Ed
Old 06-07-2013, 12:25 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
http://www.summitracing.com/parts/snn-10228/overview/
Not the supplier of choice - this should be what you are after.
I'm a bit leery of a cap as the fix - curious to know how this turns out.
Old 06-07-2013, 06:25 PM
fordf348's Avatar
Thank you for the Stant part number......I will get one and let you know how it works out
Old 06-07-2013, 06:39 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I wonder how this will come out, too. Sixty plus year old cooling system designed for 4 psi pressure now going to 7 psi. Perhaps the radiator guy sees a sale in his future.
Old 06-07-2013, 06:45 PM
tinman52's Avatar
Welder User
That is a lot of coolant to lose without a trace. Maybe install a catch can on the overflow tube and see what you get? Otherwise it could be internal......is it missing or fouling any plugs? Oil look OK?
Old 06-07-2013, 06:54 PM
Kurt G.'s Avatar
Kurt G. Kurt G. is offline
Kurt G. is starting off with a positive reputation.
I have heard of people installing too hi a pressure cap and doing damage to cooling system. I don't know if 3# increase would do it, did it work ok last year or before? Is tailpipe dry?
Old 06-07-2013, 07:43 PM
Kazoo Kazoo is offline
Kazoo is starting off with a positive reputation.
Is the existing cap new or old? Maybe 4 lb cap is just shot and not holding 4 lbs
Old 06-08-2013, 04:43 AM
fordf348's Avatar
The cap is new and the way it seats on the radiator looks good. I had figured on just going ahead and replacing the radiator but the radiator guy suggested trying the higher pressure on the cap, so if the radiator goes that is what is needed. Oil looks good, tailpipe is dry. Trying a catch can sounds like a good idea to try, it may prove where the coolant is going
Old 06-08-2013, 08:00 AM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
i thought this would be a good idea untill i did it and both water pumps blew the seals or whatever they use
Old 06-08-2013, 07:06 PM
fordf348's Avatar
Mr Need, what problems were you having when you went to the 7#cap instead of the 4?
Ed
Old 06-09-2013, 07:11 AM
my water pumps leaked around the shaft i don't think they are designed for allot of pressure ether.
Radiator Cap 69 f-100 aman 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 09-11-2014 04:57 PM
Help with new radiator. Project Completed! akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 62 08-26-2014 10:44 PM
radiator cap for an f6 tombogue09 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-03-2014 01:35 PM
What is best quality radiator cap... ? caseys Explorer, Sport Trac, Mountaineer & Aviator 14 11-01-2011 09:17 PM
Coolant Flush maticuno 1997 - 2003 F150 12 05-28-2005 11:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
