I need a 51 ford truck chassis ,Please help
I don't think anybody is ignoring your request. You got over 100 views on your first post. But I think you're seeing how rare stock frames are becoming. In the meantime, tell us how bad the one you already have is. Is your customer aware of the issue, and are you both hitting the nationwide craigslist, etc.? Can the original frame be repaired?
You may very well be forced to find a cheap rusty old resto-mod from 20 or 30 years ago, and just go from there. USUALLY, they just hacked out the original transmission crossmember and motor mounts and kept most everything else the same. Plus it sounds like you're gonna modify it further anyway. Unmolested stock frames are very hard to find nowadays. The biggest area of concern with regards to a stock frame, in my opinion, is the thin crossmember in the rear under the bed. The lower part tends to rot where it attaches to the lower part of the frame rail. But like I said, you probably need to look for a failed (or old) resto-mod with a rotten body, and just pay the difference to get the frame.
pezsox
11-27-2021 11:42 PM
abqrb2000
03-24-2013 10:52 AM
Lukas42104
27
07-11-2012 01:09 PM
