What is this hose? Brake related...
Hey guys,
I'm now in the process of doing the brakes on my truck (I'll update the build thread soon). However, I'm caught up in the rear. There is a random hose that I have no idea where it goes or what it's for. Here are some pictures:
It's on the rear left side, and it is the hose towards the bottom... The end is just sitting on the ground right now.
And here's a picture of the fitting that the hose attaches to:
Any ideas? Help is greatly appreciated. Thanks!
This is how it should look, the line clipped to the frame to keep it up, out of the way.
Also, before you put the hose back on the fitting. HIO is correct, the vent hose needs to be open not plugged. While the nipple that the hose connects to is large, the actual hole in the nipple is relatively small and plug up easily.
Make sure the little hole in the nipple is clear and not plugged up. If it is plugged, run a drill bit through it to clean it out. If you don't it could lead to unexplained axle seal leaks.
Riskyguy
06-24-2011 03:54 PM
DirtyDieselPhil
1999 to 2016 Super Duty
12-20-2004 03:50 PM
f150cobrajet
08-06-2002 04:07 AM
