A/C Evaporator/Enclosure Box Question
I am trying to find the right part number for the A/C enclosure I have. I found this page with a part number of 19B735 but I am not sure that's for my 92. http://www.thedieselstop.com/faq/9497faq/maint/stj/stjc3a02.htm
Does someone know if this part number will also work for me? Also, does this come with the protective heat insulation? Of not, I'll need to make sure I here something.
Thanks
Thanks
So I don't know if this means I should get the 87-93 part or the other. What's in that picture certainly looks like my system but I don't have a 96 or an RV. I also don't think it ever had R134A either.
A huge hole is in the evaporator cover?
Sounds like a trip to the junk yard to get that evap cover and heat shield. Some trucks had them, some did not(heat shield). I pulled one from the junkyard to put on my truck. Then mice ate it up.....at least it was just that they chewed up! ...........Added to the need list for the next junkyard run...........
You can see on the left side of my pic where some of the plastic turned white on the header, I got to get that off.
Cool setup, I though is was a turbo. Are you going to put AC back in? I doubt as the supercharger sits where the AC compressor is.
To get more room, look in the junkyard for a truck with out factory AC, and get the outside housing. That will give you more than enough room. I remember there was a thread about that either here in the 87 to 96/97 forum or the 80 to 86 forum.
If you can find a non AC truck and get the engine bay blower housing, it will take up alot less space inside the engine bay. It gets rid of the evap housing. Can't rember if you have to change out the AC/Heat box in side the cab.
I'll do some searches here for a thread about this as long as Ole TS Andrea doesn't drop another tornado on us. Just went through a pretty mean squall line and the local news had a tornado warning over my area....
https://www.ford-trucks.com/forums/1...-ac-truck.html
Here's a thread about that heat shield.. .https://www.ford-trucks.com/forums/1...d-a-c-mod.html
There would have been no way I could have repaired this without taking it completely off and seeing the holes.
I think what happened is a day a couple of weeks back, it was pretty warm around here and on that day my truck got really hot, didn't overheat. It got too hot because my fan was insufficient - I have since fixed that. But I wonder if on the day the truck got hot is when this melted.
I replaced it with the non-A/C version and stuck some of that ugly heat shielding on it. But I am going to figure out something else to put on there that looks better and is permanent.
