New to me '65 F250 4x4
Hey everybody, here shortly I'll be picking up a 65 F250 4x4 from my girlfriend's Grandma. My girlfriend's Grandpa bought it new in Denver when they were living in Cheyenne. I plan on restoring it back to original as I can. It's all original except for the cab haha. Her Uncle rolled it many years ago and somebody put on the cab to a F100 2wd. Next few days I've gotta run around and try to help her get a replacement title for it and on Tuesday were going to throw it on a trailer and drag it to my place.
Is there any way I could figure out all or most of the stuff that would have been on the original warranty plate? I've gotten the serial number off the frame but that's about it.
2wd cab from a 64 or ealier it can be converted to 4wd cab easy enough. Same with a 65 2wd cab but it wont be as original need a cab with the inside step for 4wd. Good luck with it and try to post up some pics of it that are a little bigger and welcom to FTE fellow 4wder. Great to see all these 4wd getting back on the road.
Edit if 4 speed trans it would most likely be an NP 435. Unless that has been changed. Look at pics of my builds in projects forum and you will see alot of what is suppose to be stock on these rigs.
If the cab has been changed, I would assume the doors have too, which means none of the codes including the VIN stamped on the Warranty Plate (located on left door face below latch) will match original configuration.
Since the IDIOTS at FoMoCo THREW AWAY all the records for these trucks decades ago, there's no way to discover how they were originally equipped.
Cab step, visible when doors are opened: 1961/64 F100/1100 / 1965 F100/250 4WD / 1965/66 F350/1100 / 1966 F250 4WD
No cab step: 1965/66 F100/250 2WD / 1966 F100 4WD
Yeah the entire cab and doors were replaced and as usual they didn't replace the warranty plate. The serial number off the frame is: F26DR590257 and on the warranty plate on the door is F10JK512126.
The pictures above should link to bigger ones. I wasn't sure how big they were and didn't want to blow up everybody's screen with giant pictures.
F10 = F100 2WD / J = 223 I-6 / K = Kansas City MO Assembly Plant / 512126 = 1964 .. assembled March 1964.
F260 = F250 4WD ~ 6,800 lbs. GVWR / F261 = F250 4WD ~ 4,900 lbs. GVWR / F262 = F250 4WD ~ 7,700 lbs. GVWR
GVWR = Gross Vehicle Weight Rating.
Dana front/rear axle ID tag located under one of the bolts that retains inspection cover to housing, but today...many of these tags are missing.
Weight of truck, driver, passengers and cargo should not exceed GVWR, otherwise as you can see, Warranty void.
