95 Explorer Cam Sensor
Hello!
I have a 95 Explorer XLT with the 4.0 liter pushrod V-6. I just recently started getting a check engine light, so I purchased a code reader. Upon scanning the codes, I learned that I had bad O2 sensors and a bad CID sensor. I replaced the O2 sensors and ran the scanner again. The O2 sensor code is gone, however, the CID sensor code remains along with the check engine light. I've come to decide that I need to replace the CID sensor. However, I've been told (by the local ford dealer) that the 95's have a one-piece unit, in which you cannot simply remove the sensor. The dealer told me that I have to remove the entire drive/sensor assembly... and that he would be quite happy to sell me a new one for a mere $370.00!!! I'm wondering if all this sounds accurate. Also, I inspected my sensor unit pretty closely, there ARE two screws on top, which suggest to me that the sensor might just come off. (I've yet to get an opportunity to get those screws out to find out). Thanks for any help you can offer!!!
Steve
Steve
There are 2 screws on top, but Ford only sells the sensor & drive assembly.
$370 is not a bad price! Expressautoparts.com gets $347 for an aftermarket (Standard brand) unit.
Results from search at Expressautoparts.com:
Click on the add to cart icon to add an item to your shopping cart.
Search Results:
1995 Ford
EXPLORER : Different Car?
Sensors: SENSOR, CAMSHAFT POSITION
Part No. Description List Your Price Buy
Estimated Ground Shipping Time:
3-6 days (based on your proximity to our warehouse network) *
STANDARD
PC137 [CAM & CRANKSHAFT SENSOR-CAMSHAFT SENSOR] $542.03 $347.66
Search Results:
1995 Ford
STANDARD
charles5000
01-28-2014 07:31 AM
1998Ranger25L153CID
05-17-2010 06:53 PM
97ExplorerEB
07-26-2007 08:50 PM
geoaigel
1983 - 2012 Ranger & B-Series
01-10-2005 10:50 AM
