Dpf delete in California...
Hey everyone, I'm still kinda new to the forum and to diesels. I've heard a lot of people talking about deleting the dpf for better gas mileage. My question is...can I delete the dpf with a delete pipe and reinstall it when it comes time for a smog/emissions check? I would love to hear from any other Ca. residents that may have done a dpf delete and deal with smog checks. Also, is it possible to use a delete pipe with stock exhaust? Don't know if this is something I can bring to a muffler shop and ask them to do or if I can do it myself. I'm pretty mechanically inclined and know how to wrench on things...to an extent. I'm really not interested in installing a tuner if I don't have too. I'm strictly concerned about mpg and not interested in increasing the hp. Also, if I can delete the dpf, are there any other things that need to be adjusted (e.g. Sensors, service engine lights, etc) or does the dpf just come out and all is good? My final question is...will the mpg increase be significant? I'm currently getting 13 mpg city driving only.
I appreciate any advice I can get.
Thank you
Dave
Thank you
Dave
Yes you can, takes a couple hours at the most. I can't comment about California. I read on here that they do road blocks out there to check emissions. I have camped in 48 of the 49 reachable states, I will not go to cal. Besides being in a modified truck I am armed. As I hear it I would be in trouble if stopped there. You cannot have delete pipe and stock exhaust. Delete pipe replaces about 4 feet of the stock exhaust. You should be able to replace the DPF/DOC as a DIY project, it is not difficult. If you delete the DPF you must have some kind of tuner to change the truck computer. Some tuners let you remove the exhaust sensors, others don't. Fuel mileage gain will not be dramatic, maybe 15-20%. Might get you from 13 to 15. What it will do is make your truck run sooooo much better and stop the oil dilution. I suggest you do some homework by reading some of the hundreds of posts on this forum on the delete/tuner subject. You will then be able to make your own decision on what you want. Good luck.
That's interesting, I've read several stories on line about it. But, it is the internet.
I would NOT risk it in California. Deleting the DPF allows for soot to exhaust from the tail pipe and with the crazy laws out there, you're risking a $10,000 fine if caught. A police officer, state trooper, or any other goverment agent can stop you if they know about emissions equipment laws and the model years that trucks should have it. I know we all are risking that, but the chances of getting caught in CA is extremely elevated.
On another note, if you're ONLY driving is city and you're truly getting 13, not shown on instrument cluster, but hand calculated, and you have a DPF, you're doing pretty good.
If its on the Internet, it must be true.
This is why mine is cone. The regen was putting fuel in my oil. last oil report 2%. If I let that continue my concern was the cost of a 6.4 replacement.
Thanks
Dave
Blackstone labs does oil analysis. Google them. ANY fuel in your oil is BAD. Diesel fuel is not very lubricating at all and diluting your oil can cause premature wear and failure. The lowest you can get on a report is "<0.5%" which is basically zero but I don't think the testing/methodology used can actually yield a "0%". Ford says <5% is acceptable but independent research/opinions state otherwise.
Other than dilution, fuel in the oil causes the oil level to grow. An over full crankcase is also very bad. Risking a runaway engine among other problems.
Deleting is actually the solution to oil dilution/growth. However, many people are getting <0.5% on their reports that aren't deleted.
Thanks again.
Once again, thank you for being patient with me. I appreciate all the info.
Dave
http://lmgtfy.com/?q=Banks+six+gun+CARB+approved
http://lmgtfy.com/?q=Blackstone+labs
Blackstone will send you a free collection kit. You may want a Fumoto Oil Valve for ease of sampling.
http://lmgtfy.com/?q=Fumoto+oil+change+valve+ford+6.4
