electric fuel pump? - Ford Truck Enthusiasts Forums
electric fuel pump?
Old 06-04-2013, 09:30 PM
XTfx4 XTfx4 is offline
XTfx4 is starting off with a positive reputation.
electric fuel pump?
recently my mech. pump went a friend of mine wired in an electric pump he had on hand. couple of questions . . . . is this "better" than a mech. pump, should i get a block off plate if i keep the electric? and a question about the wiring....... is the pump suppose to run continuously while the key is in the on position? like if i wanted to listen to the radio without truck running .... and also if the key was turned to the left for just the radio , should it be running then ??? b/c mine runs all the time? is it always pumping gas into the carb for as long as i have the key turned ? is this correct? should i just go back to mech? i know alot of ???? any help thanks a lot!!!!! by the way its a 79 350 4wd with a 400. edelbrock carb and intake .
Old 06-04-2013, 09:38 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Quote:
I have no idea what you just said.
The pump should be wired off the hot-in-RUN circuit. You should place an inertia switch as well as an oil pressure cut-off switch in the path such that the fuel pump shuts OFF in the event of a collision, or low oil pressure.
You must have wired the pump off the accessory circuit which is wrong. The pump should not be running during conditions in which the motor is not in use.
You are mixing two questions into one. The pump should only be RUNNING with the key in RUN. It should NOT be running with the key in ACC. When the pump is RUNNING, it only pumps as much fuel as allowed by the carburetor. The concept is no different than with a mechanical pump. When the fuel bowl in the carburetor is full, the carburetor inlet is shut off by the needle and seat. The fuel pump continues to run, but does not actually push fuel forward.
Why, what's the problem? Your pump is wired wrong; that doesn't mean a mechanical pump is any better or worse.
Next time, please slow down and use a little more punctuation and fewer abbreviations. Your post looks like a text message and is very hard to read.
Old 06-04-2013, 10:13 PM
MeanGreen460 MeanGreen460 is offline
MeanGreen460 is starting off with a positive reputation.
Personally I would put a new mechanical fuel pump back on.
Old 06-04-2013, 10:22 PM
Blue and White Blue and White is online now
Blue and White is gaining momentum as a positive member of FTE.
On a carb vehicle I think of the electric pump as a "problem solver". Vapor lock problems in hot weather? The electric pump will help. Really long cranking on an engine that has sat for a while? Electric pump will help. I run an auxiliary electric on another brand 40's era PU with chronic vapor lock problems in hot weather. Problem solved.
My dent is happy with its mechanical pump. Once I got the soggy fuel lines replaced, no fuel problems including 100 degree temps. I think the mechanical pump is best. Its simple, low cost and inherently "safe" since it stops pumping when the engine stops. I'd put a mechanical pump back on personally.
Old 06-05-2013, 11:30 AM
wotan's Avatar
wotan wotan is offline
wotan is starting off with a positive reputation.
My dent is the first vehicle I've ever had that didn't have an aux electric pump added. I ran into my first problem when I ran out of gas and couldn't get the mechanical pump to prime....
I'm now considering piggy-backing an electric one on there to help with this situation and to make starts easier.
Old 06-05-2013, 12:30 PM
chris989 chris989 is offline
chris989 is starting off with a positive reputation.
Quote:
X2, the mechanical pump will never let you down. the last one lasted 30 plus years?
chris
Old 06-05-2013, 02:21 PM
Old Coyote Old Coyote is offline
Old Coyote is starting off with a positive reputation.
One of my trucks has an electric pump installed by the PO. I'm not sure why. Anyway, it was installed to operate in Run but of course was still a problem. It pumped fuel when the ignition was in run and the engine not running (such as during a stall). Even worse, it could also keep pumping fuel during a ditch or a roll and then you've got fuel going everywhere. I installed an oil switch relay I orderer from Jegs so the pump only runs when the engine is running. Do yourself and your passengers a favour and do the same if you are going electric, or go back to mechanical.
Dies out of random, like out of fuel Mengquis Ford Inline Six, 200, 250, 4.9L / 300 3 11-09-2016 10:18 PM
Fuel Pump Questions tlb 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 05-28-2016 01:19 PM
Swapping out mechanical pump for electric? WeldorJP Fuel Injection, Carburetion & Fuel System 12 02-23-2013 07:47 AM
Mechanical or Electric Fuel pump Joejustatruck 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-24-2012 12:49 PM
Inline Fuel Pump to replace Mech Question nwo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 07-30-2011 12:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
