1994 f350 460 question - Ford Truck Enthusiasts Forums
Old 06-04-2013, 09:26 PM
matacemat matacemat is offline
matacemat is starting off with a positive reputation.
Hello. I am replacing head gaskets on a 94 f350 with a 460 in it. Can anyone tell me if the efi 460 uses torque to yield head bolts. I googled and some say yes and some say no. If i do need to replace them, i can only find an arp part number that lists them for use with Edelbrock heads. Any tip on those would be great. Thanks
Old 06-04-2013, 09:53 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
No, they do not, they're just a pain to get loose and retorqued.
75 460 timing 75 Camper Special 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-24-2014 02:13 AM
Edelbrock carb install question 5280 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 04-23-2014 10:31 PM
Will Edelbrock 390 FE Carb, Intake, & Heads work on a 360 FE? GamerGirlAlice 1967 - 1972 F-100 & Larger F-Series Trucks 9 01-18-2013 12:15 AM
building a 460 EFI engine to get over 500 hp Musclestang Performance & General Engine Building 4 03-09-2004 11:44 PM
Aftermarket Carb for 1978 460 Scavenger Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 12-06-2001 03:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
