48-52 hubs - Ford Truck Enthusiasts Forums
48-52 hubs
Old 06-04-2013, 09:11 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is offline
fifty-two_f1 is starting off with a positive reputation.
48-52 hubs
Will 1963 f100 hubs work on a 48-52 axle? none of my parts books go this new....
Thanks guys!
Old 06-05-2013, 07:15 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
My 48-56 parts book shows the front drum changes part number between 52 and 53.
Old 06-07-2013, 08:41 AM
OldGrayMare's Avatar
OldGrayMare OldGrayMare is offline
OldGrayMare is gaining momentum as a positive member of FTE.
I found some dimensions on the drums that show they did change starting in 1953.
The Hub register changed from 2.88" to 3.16"
The friction surface changed from 2.11" to 2.42" - This caused the overall width to change 1/4" from 2.79" to 3.04"
This means you would have to keep the newer drums with newer hubs, but it would not keep them from working on the 48 to 52 year models if you had a matched set.
Old 06-07-2013, 10:54 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Pretty sure bearings changed in 53 too.
Old 06-08-2013, 02:00 PM
Well looks like the 63s wont work. Ill hunt around for some 48-52s.
Want to buy....... Mr. Ed 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-26-2016 10:25 AM
48-56 Front brake differences fifty-two_f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 02-27-2016 01:28 PM
52 Front roll pan??? Mitch1129 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 02-17-2015 08:56 AM
48-52 Are all 4 Front Brake Shoes the Same? Schmitty 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-23-2010 07:47 PM
48-52 soft bed covers? CAPTAIN 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 04-10-2010 01:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
